Datasheet ADA4855-3 (Analog Devices) - 2
ОписаниеSingle Supply, High Speed, Rail-to-Rail Output, Triple Op Amp
Страниц / Страница21 / 2 — ADA4855-3* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
ВерсияA
Формат / Размер файлаPDF / 596 Кб
ADA4855-3* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. REFERENCE MATERIALS. Tutorials
ADA4855-3* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS REFERENCE MATERIALS Tutorials
View a parametric search of comparable parts.
Tutorials
• MT-032: Ideal Voltage Feedback (VFB) Op Amp
EVALUATION KITS
• MT-033: Voltage Feedback Op Amp Gain and Bandwidth • ADA4855-3 Evaluation Board • MT-047: Op Amp Noise • MT-048: Op Amp Noise Relationships: 1/f Noise, RMS
DOCUMENTATION
Noise, and Equivalent Noise Bandwidth
Application Notes
• MT-049: Op Amp Total Output Noise Calculations for • AN-402: Replacing Output Clamping Op Amps with Input Single-Pole System Clamping Amps • MT-050: Op Amp Total Output Noise Calculations for • AN-417: Fast Rail-to-Rail Operational Amplifiers Ease Second-Order System Design Constraints in Low Voltage High Speed Systems • MT-052: Op Amp Noise Figure: Don't Be Misled • AN-581: Biasing and Decoupling Op Amps in Single • MT-053: Op Amp Distortion: HD, THD, THD + N, IMD, Supply Applications SFDR, MTPR
Data Sheet
• MT-056: High Speed Voltage Feedback Op Amps • ADA4855-3: Single Supply, High Speed, Rail-to-Rail • MT-058: Effects of Feedback Capacitance on VFB and CFB Output, Triple Op Amp Data Sheet Op Amps
User Guides
• MT-059: Compensating for the Effects of Input • UG-115: Universal Evaluation Board for Triple, High Speed Capacitance on VFB and CFB Op Amps Used in Current-to- Op Amps Offered in 16-Lead, 4 mm × 4 mm LFCSP Voltage Converters Packages • MT-060: Choosing Between Voltage Feedback and Current Feedback Op Amps
TOOLS AND SIMULATIONS DESIGN RESOURCES
• Analog Filter Wizard • Analog Photodiode Wizard • ADA4855-3 Material Declaration • Power Dissipation vs Die Temp • PCN-PDN Information • VRMS/dBm/dBu/dBV calculators • Quality And Reliability • ADA4855 SPICE Macro Model • Symbols and Footprints
DISCUSSIONS
View all ADA4855-3 EngineerZone Discussions.
SAMPLE AND BUY
Visit the product page to see pricing options.
TECHNICAL SUPPORT
Submit a technical question or find your regional support number.
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
Document Outline Features Applications Connection Diagram General Description Revision History Specifications 5 V Operation 3.3 V Operation Absolute Maximum Ratings Thermal Resistance Maximum Power Dissipation ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Test Circuits Theory of Operation Applications Information Gain Configurations 20 MHz Active Low-Pass Filter RGB Video Driver Driving Multiple Video Loads PD (Power-Down) Pin Single-Supply Operation Power Supply Bypassing Layout Outline Dimensions Ordering Guide
