Datasheet ADA4311-1 (Analog Devices) - 10
ОписаниеLow Cost, Dual, High Current Output Line Driver with Shutdown
Страниц / Страница17 / 10 — ADA4311-1. –20. PD1, PD0 = 1, 1. –40. B) d. H (. ( –40. UG O –60. AL T. S …
Формат / Размер файлаPDF / 304 Кб
ADA4311-1. –20. PD1, PD0 = 1, 1. –40. B) d. H (. ( –40. UG O –60. AL T. S S. O –60. E E. –80. –100. 100. 1000. 0.1. FREQUENCY (MHz). FREQUENCY (Hz). VOUT. G A
ADA4311-1 –20 PD1, PD0 = 1, 1 –40 B) d H ( ( –40 UG O –60 AL T S S O –60 E E –80 –100 100 1000 0.1 FREQUENCY (MHz) FREQUENCY (Hz) VOUT G A
ADA4311-1 –20 0 PD1, PD0 = 1, 1 –20 –40 B) d B) d H ( ( –40 K UG O –60 AL T HR S S DT O –60 E E CR F –80 –80 –100 –100 1 10 100 1000
7 14 0
0.1 1 10 100 1000
01 0- 0-
FREQUENCY (MHz)
94
FREQUENCY (Hz)
94 06 06 Figure 17. Feedthrough vs. Frequency Figure 19. Crosstalk vs. Frequency
8 12 7 VOUT 11 6 10 ) 5 (V ) E -p G A 4 (p 9 T T L OUV VO 3 8 VPD1, VPD0 2 7 1
6 01 0- 94
0 6
0 06
0 1 2 3 4 5 6
02
30 100 1000
0-
TIME (1μs/DIV)
94
LOAD (Ω)
06 Figure 18. Power-Down Turn On/Turn Off Figure 20. Single-Ended Output Swing vs. Load Rev. 0 | Page 9 of 16 Document Outline FEATURES APPLICATIONS PIN CONFIGURATION TYPICAL APPLICATION GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Maximum Power Dissipation ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATION INFORMATION FEEDBACK RESISTOR SELECTION POWER CONTROL MODES OF OPERATION EXPOSED THERMAL PAD CONNECTIONS POWERLINE APPLICATION BOARD LAYOUT POWER SUPPLY BYPASSING OUTLINE DIMENSIONS ORDERING GUIDE
