Линейка продуктов KEEN SIDE
Datasheet ADA4000-1, ADA4000-2, ADA4000-4 (Analog Devices) - 5
ОписаниеLow Cost, Precision JFET Input Operational Amplifiers
Страниц / Страница16 / 5 — Data Sheet. ADA4000-1/ADA4000-2/ADA4000-4. ABSOLUTE MAXIMUM RATINGS Table …
ВерсияB
Формат / Размер файлаPDF / 585 Кб
Data Sheet. ADA4000-1/ADA4000-2/ADA4000-4. ABSOLUTE MAXIMUM RATINGS Table 3. THERMAL RESISTANCE. Parameter. Rating
Data Sheet ADA4000-1/ADA4000-2/ADA4000-4 ABSOLUTE MAXIMUM RATINGS Table 3 THERMAL RESISTANCE Parameter Rating
28 предложений от 14 поставщиков
Микросхема Операционный усилитель, IC OPAMP JFET 5MHz 8SOIC
ADA4000-1ARZ-R7
от 94 ₽
ADA4000-1ARZ-R7
257 ₽
ADA4000-1ARZ-R7
ADA4000-1ARZ-R7
Data Sheet ADA4000-1/ADA4000-2/ADA4000-4 ABSOLUTE MAXIMUM RATINGS Table 3. THERMAL RESISTANCE Parameter Rating
θJA is specified for the worst-case conditions, that is, a device Supply Voltage ±18 V soldered in a circuit board for surface-mount packages. Input Voltage ±V supply Differential Input Voltage ±V supply
Table 4. Thermal Resistance
Output Short-Circuit Duration to GND Indefinite
Package Type θJA θJC Unit
Storage Temperature Range −65°C to +150°C 5-Lead TSOT (UJ-5) 172.92 61.76 °C/W Operating Temperature Range −40°C to +125°C 8-Lead SOIC (R-8) 112.38 61.6 °C/W Junction Temperature Range −65°C to +150°C 8-Lead MSOP (RM-8) 141.9 43.7 °C/W Lead Temperature (Soldering, 10 sec) 300°C 14-Lead SOIC (R-14) 88.2 56.3 °C/W 14-Lead TSSOP (RU-14) 114 23.3 °C/W Stresses at or above those listed under Absolute Maximum Ratings may cause permanent damage to the product. This is a
POWER SEQUENCING
stress rating only; functional operation of the product at these The operational amplifier supply voltages must be established or any other conditions above those indicated in the operational simultaneously with, or before, any input signals are applied. If section of this specification is not implied. Operation beyond this is not possible, the input current must be limited to 10 mA. the maximum operating conditions for extended periods may
ESD CAUTION
affect product reliability. Rev. B | Page 5 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATIONS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE POWER SEQUENCING ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION OUTPUT PHASE REVERSAL AND INPUT NOISE CAPACITIVE LOAD DRIVE SETTLING TIME OUTLINE DIMENSIONS ORDERING GUIDE
