Datasheet AD8625, AD8626, AD8627 (Analog Devices) - 4
ОписаниеPrecision Low Power Single-Supply JFET Amplifiers
Страниц / Страница20 / 4 — AD8625/AD8626/AD8627. Data Sheet. Table 2. Parameter. Symbol. Conditions. …
ВерсияF
Формат / Размер файлаPDF / 290 Кб
AD8625/AD8626/AD8627. Data Sheet. Table 2. Parameter. Symbol. Conditions. Min. Typ. Max. Unit
AD8625/AD8626/AD8627 Data Sheet Table 2 Parameter Symbol Conditions Min Typ Max Unit
52 предложений от 22 поставщиков
Микросхема Операционный усилитель, ANALOG DEVICES AD8627AKSZ-REEL7 Operational Amplifier, Single, 1 Amplifier, 5MHz, 5V/µs, 5V to 26V, SC-70, 5Pins
ЧипСити
AD8627AKSZ-REEL7
129 ₽
Элрус
AD8627AKSZ-REEL7
от 321 ₽
727GS
AD8627AKSZ-REEL
от 335 ₽
TradeElectronics
AD8627AKSZ-REEL7
@VS = ±13 V; VCM = 0 V; TA = 25°C, unless otherwise noted.
Table 2. Parameter Symbol Conditions Min Typ Max Unit
INPUT CHARACTERISTICS Offset Voltage VOS 0.35 0.75 mV –40°C < TA < +85°C 1.35 mV Input Bias Current IB 0.25 1 pA –40°C < TA < +85°C 60 pA Input Offset Current IOS 0.5 pA –40°C < TA < +85°C 25 pA Input Voltage Range –13 +11 V Common-Mode Rejection Ratio CMRR VCM = –13 V to +10 V 76 105 dB Large Signal Voltage Gain AVO RL = 10 kΩ, VO = –11 V to +11 V 150 310 V/mV Offset Voltage Drift ∆VOS/∆T –40°C < TA < +85°C 2.5 µV/°C OUTPUT CHARACTERISTICS Output Voltage High VOH +12.92 V VOH IL = 2 mA, –40°C < TA < +85°C +12.91 V Output Voltage Low VOL –12.92 V VOL IL = 2 mA, –40°C < TA < +85°C –12.91 V Output Current IOUT ±15 mA POWER SUPPLY Power-Supply Rejection Ratio PSRR VS = ±2.5 V to ±13 V 80 104 dB Supply Current/Amplifier ISY 710 850 µA –40°C < TA < +85°C 900 µA DYNAMIC PERFORMANCE Slew Rate SR 5 V/µs Gain Bandwidth Product GBP 5 MHz Phase Margin ØM 60 Degrees NOISE PERFORMANCE Voltage Noise en p-p 0.1 Hz to 10 Hz 2.5 µV p-p Voltage Noise Density en f = 1 kHz 16 nV/√Hz Current Noise Density in f = 1 kHz 0.5 fA/√Hz Channel Separation Cs f = 1 kHz 105 dB Rev. F | Page 4 of 20 Document Outline Features Applications Pin Configurations General Description Revision History Specifications Electrical Characteristics Absolute Maximum Ratings ESD Caution Typical Performance Characteristics Applications Information Minimizing Input Current Photodiode Preamplifier Application Output Amplifier for DACs Eight-Pole Sallen Key Low-Pass Filter Outline Dimensions Ordering Guide
