Datasheet AD8067 (Analog Devices) - 2
ОписаниеHigh Gain Bandwidth Product, Precision FastFET™ Op Amp
Страниц / Страница26 / 2 — AD8067* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
ВерсияB
Формат / Размер файлаPDF / 447 Кб
AD8067* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. REFERENCE MATERIALS
AD8067* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS REFERENCE MATERIALS
View a parametric search of comparable parts.
Product Selection Guide
• High Speed Amplifiers Selection Table
EVALUATION KITS Tutorials
• Universal Evaluation Board for Single High Speed • MT-032: Ideal Voltage Feedback (VFB) Op Amp Operational Amplifiers • MT-033: Voltage Feedback Op Amp Gain and Bandwidth • MT-047: Op Amp Noise
DOCUMENTATION
• MT-048: Op Amp Noise Relationships: 1/f Noise, RMS
Application Notes
Noise, and Equivalent Noise Bandwidth • AN-402: Replacing Output Clamping Op Amps with Input • MT-049: Op Amp Total Output Noise Calculations for Clamping Amps Single-Pole System • AN-417: Fast Rail-to-Rail Operational Amplifiers Ease • MT-050: Op Amp Total Output Noise Calculations for Design Constraints in Low Voltage High Speed Systems Second-Order System • AN-581: Biasing and Decoupling Op Amps in Single • MT-052: Op Amp Noise Figure: Don't Be Misled Supply Applications • MT-053: Op Amp Distortion: HD, THD, THD + N, IMD, • AN-649: Using the Analog Devices Active Filter Design SFDR, MTPR Tool • MT-056: High Speed Voltage Feedback Op Amps
Data Sheet
• MT-058: Effects of Feedback Capacitance on VFB and CFB • AD8067: High Gain Bandwidth Product, Precision Fast Op Amps FET™ Op Amp Datasheet • MT-059: Compensating for the Effects of Input
User Guides
Capacitance on VFB and CFB Op Amps Used in Current-to- • UG-838: Evaluation Board for Single, High Speed Op Amps Voltage Converters Offered in 5-Lead SOT-23 and 6-Lead SOT-23 Packages • MT-060: Choosing Between Voltage Feedback and Current Feedback Op Amps
TOOLS AND SIMULATIONS
• Analog Filter Wizard
DESIGN RESOURCES
• Analog Photodiode Wizard • AD8067 Material Declaration • Power Dissipation vs Die Temp • PCN-PDN Information • VRMS/dBm/dBu/dBV calculators • Quality And Reliability • AD8067 SPICE Macro Model • Symbols and Footprints
DISCUSSIONS
View all AD8067 EngineerZone Discussions.
SAMPLE AND BUY
Visit the product page to see pricing options.
TECHNICAL SUPPORT
Submit a technical question or find your regional support number. Document Outline Features Applications Connection Diagram (Top View) General Description Revision History Specifications for ±5 V Specifications for +5 V Specifications for ±12 V Absolute Maximum Ratings Maximum Power Dissipation ESD Caution Typical Performance Characteristics Test Circuits Theory of Operation Basic Frequency Response Resistor Selection for Wideband Operation DC Error Calculations Input and Output Overload Behavior Input Protection Capacitive Load Drive Layout, Grounding, and Bypassing Considerations Layout Grounding Power Supply Bypassing Applications Wideband Photodiode Preamp Using the AD8067 at Gains of Less Than 8 Single-Supply Operation High Gain, High Bandwidth Composite Amplifier Outline Dimensions Ordering Guide
