Datasheet AD8038, AD8039 (Analog Devices) - 3
ОписаниеLow Power, 350 MHz Voltage Feedback Amplifiers
Страниц / Страница16 / 3 — AD8038/AD8039. SPECIFICATIONS. Table 1. Parameter. Conditions. Min. Typ. …
ВерсияG
Формат / Размер файлаPDF / 305 Кб
AD8038/AD8039. SPECIFICATIONS. Table 1. Parameter. Conditions. Min. Typ. Max. Unit
AD8038/AD8039 SPECIFICATIONS Table 1 Parameter Conditions Min Typ Max Unit
30 предложений от 12 поставщиков
AD8039SRZ-EPR7
186 ₽
AD8039SRZ-EPR7
285 ₽
AD8039SRZ-EPR7
463 ₽
Эиком
AD8039SRZ-EPR7
от 793 ₽
link to page 3
TA = 25°C, VS = ±5 V, RL = 2 kΩ, Gain = +1, unless otherwise noted.
Table 1. Parameter Conditions Min Typ Max Unit
DYNAMIC PERFORMANCE −3 dB Bandwidth G = +1, VO = 0.5 V p-p 300 350 MHz G = +2, VO = 0.5 V p-p 175 MHz G = +1, VO = 2 V p-p 100 MHz Bandwidth for 0.1 dB Flatness G = +2, VO = 0.2 V p-p 45 MHz Slew Rate G = +1, VO = 2 V step, RL = 2 kΩ 400 425 V/μs Overdrive Recovery Time G = +2, 1 V overdrive 50 ns Settling Time to 0.1% G = +2, VO = 2 V step 18 ns NOISE/HARMONIC PERFORMANCE SFDR Second Harmonic fC = 1 MHz, VO = 2 V p-p, RL = 2 kΩ −90 dBc Third Harmonic fC = 1 MHz, VO = 2 V p-p, RL = 2 kΩ −92 dBc Second Harmonic fC = 5 MHz, VO = 2 V p-p, RL = 2 kΩ −65 dBc Third Harmonic fC = 5 MHz, VO = 2 V p-p, RL = 2 kΩ −70 dBc Crosstalk, Output-to-Output (AD8039) f = 5 MHz, G = +2 −70 dB Input Voltage Noise f = 100 kHz 8 nV/√Hz Input Current Noise f = 100 kHz 600 fA/√Hz DC PERFORMANCE Input Offset Voltage 0.5 3 mV Input Offset Voltage Drift 4.5 μV/°C Input Bias Current 400 750 nA Input Bias Current Drift 3 nA/°C Input Offset Current ±25 nA Open-Loop Gain VO = ±2.5 V 70 dB INPUT CHARACTERISTICS Input Resistance 10 MΩ Input Capacitance 2 pF Input Common-Mode Voltage Range RL = 1 kΩ ±4 V Common-Mode Rejection Ratio VCM = ±2.5 V 61 67 dB OUTPUT CHARACTERISTICS DC Output Voltage Swing RL = 2 kΩ, saturated output ±4 V Capacitive Load Drive 30% overshoot, G = +2 20 pF POWER SUPPLY Operating Range 3.0 12 V Quiescent Current per Amplifier 1.0 1.5 mA Power Supply Rejection Ratio −Supply −71 −77 dB +Supply −64 −70 dB POWER-DOWN DISABLE1 Turn-On Time 180 ns Turn-Off Time 700 ns Disable Voltage—Part is Off +VS − 4.5 V Disable Voltage—Part is On +VS − 2.5 V Disabled Quiescent Current 0.2 mA Disabled In/Out Isolation f = 1 MHz −60 dB 1 Only available in AD8038 8-lead SOIC package. Rev. G | Page 3 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION OUTPUT SHORT CIRCUIT ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS LAYOUT, GROUNDING, AND BYPASSING CONSIDERATIONS DISABLE POWER SUPPLY BYPASSING GROUNDING INPUT CAPACITANCE OUTPUT CAPACITANCE INPUT-TO-OUTPUT COUPLING APPLICATIONS INFORMATION LOW POWER ADC DRIVER LOW POWER ACTIVE VIDEO FILTER OUTLINE DIMENSIONS ORDERING GUIDE
