Datasheet AD8571, AD8572, AD8574 (Analog Devices) - 6
ОписаниеZero-Drift, Single-Supply, Rail-to-Rail Input/Output Operational Amplifiers
Страниц / Страница28 / 6 — AD8571/AD8572/AD8574. Data Sheet. ABSOLUTE MAXIMUM RATINGS. Table 3. …
ВерсияF
Формат / Размер файлаPDF / 488 Кб
AD8571/AD8572/AD8574. Data Sheet. ABSOLUTE MAXIMUM RATINGS. Table 3. Parameter. Rating. THERMAL CHARACTERISTICS
AD8571/AD8572/AD8574 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 3 Parameter Rating THERMAL CHARACTERISTICS
IC OPAMP ZER-DRIFT 4CIRC 14TSSOP. Zero-Drift Amplifier 4 Circuit Rail-to-Rail 14-TSSOP. Linear - Amplifiers - Instrumentation, OP Amps, Buffer Amps
AD8574TRU-EP-RL
581 ₽
AD8574TRU-EP-RL
772 ₽
Рутоника
AD8574TRU-EP-RL
AD8574TRU-EP-RL
AD8571/AD8572/AD8574 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 3.
Stresses at or above those listed under Absolute Maximum
Parameter Rating
Ratings may cause permanent damage to the product. This is a Supply Voltage 6 V stress rating only; functional operation of the product at these or any other conditions above those indicated in the operational Input Voltage GND − 0.3 V to VS + 0.3 V section of this specification is not implied. Operation beyond Differential Input Voltage1 ±5.0 V the maximum operating conditions for extended periods may ESD (Human Body Model) 2000 V affect product reliability. Output Short-Circuit Duration to GND Indefinite Storage Temperature Range −65°C to +150°C
Operating Temperature Range −40°C to +125°C θ Junction Temperature Range −65°C to +150°C JA is specified for the worst-case conditions, that is, θJA is specified for a device soldered in a circuit board for SOIC and Lead Temperature (Soldering, 60 sec) 300°C TSSOP packages. 1 Differential input voltage is limited to ±5.0 V or the supply voltage, whichever is less.
Table 4. Thermal Resistance Package Type θJA θJC Unit
8-Lead SOIC (R) 158 43 °C/W 8-Lead MSOP (RM) 190 44 °C/W 8-Lead TSSOP (RU) 240 43 °C/W 14-Lead SOIC (R) 120 36 °C/W 14-Lead TSSOP (RU) 180 36 °C/W
ESD CAUTION
Rev. F | Page 6 of 28 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATIONS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS 5 V ELECTRICAL CHARACTERISTICS 2.7 V ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL CHARACTERISTICS ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS FUNCTIONAL DESCRIPTION AMPLIFIER ARCHITECTURE BASIC AUTO-ZERO AMPLIFIER THEORY AUTO-ZERO PHASE AMPLIFICATION PHASE HIGH GAIN, CMRR, AND PSRR MAXIMIZING PERFORMANCE THROUGH PROPER LAYOUT 1/f NOISE CHARACTERISTICS RANDOM AUTO-ZERO CORRECTION ELIMINATES INTERMODULATION DISTORTION BROADBAND AND EXTERNAL RESISTOR NOISE CONSIDERATIONS OUTPUT OVERDRIVE RECOVERY INPUT OVERVOLTAGE PROTECTION OUTPUT PHASE REVERSAL CAPACITIVE LOAD DRIVE POWER-UP BEHAVIOR APPLICATIONS INFORMATION 5 V PRECISION STRAIN GAGE CIRCUIT 3 V INSTRUMENTATION AMPLIFIER HIGH ACCURACY THERMOCOUPLE AMPLIFIER PRECISION CURRENT METER PRECISION VOLTAGE COMPARATOR OUTLINE DIMENSIONS ORDERING GUIDE
