Datasheet OP184, OP284, OP484 (Analog Devices) - 5
ОписаниеSingle-Supply Rail-to-Rail Input/Output Operational Amplifier
Страниц / Страница24 / 5 — OP184/OP284/OP484. Table 4. Parameter. Symbol. Conditions. Min. Typ. Max. …
ВерсияJ
Формат / Размер файлаPDF / 685 Кб
OP184/OP284/OP484. Table 4. Parameter. Symbol. Conditions. Min. Typ. Max. Unit
OP184/OP284/OP484 Table 4 Parameter Symbol Conditions Min Typ Max Unit
56 предложений от 23 поставщиков
Рутоника
OP484ESZ-REEL
920 ₽
Зенер
Россия и страны ТС
OP484ESZ-REEL
от 1 148 ₽
OP484ESZ-REEL
1 517 ₽
Эиком
OP484ESZ-REEL
от 2 662 ₽
link to page 5
OP184/OP284/OP484
VS = ±15.0 V, VCM = 0 V, TA = 25°C, unless otherwise noted.
Table 4. Parameter Symbol Conditions Min Typ Max Unit
INPUT CHARACTERISTICS Offset Voltage, OP184/OP284E Grade1 VOS 100 μV −40°C ≤ TA ≤ +125°C 200 μV Offset Voltage, OP184/OP284F Grade1 VOS 175 μV −40°C ≤ TA ≤ +125°C 375 μV Offset Voltage, OP484E Grade1 VOS 150 μV −40°C ≤ TA ≤ +125°C 300 μV Offset Voltage, OP484F Grade1 VOS 250 μV −40°C ≤ TA ≤ +125°C 500 μV Input Bias Current IB 80 450 nA −40°C ≤ TA ≤ +125°C 575 nA Input Offset Current IOS −40°C ≤ TA ≤ +125°C 50 nA Input Voltage Range −15 +15 V Common-Mode Rejection Ratio CMRR VCM = −14.0 V to +14.0 V, −40°C ≤ TA ≤ +125°C 86 90 dB VCM = −15.0 V to +15.0 V 80 dB Large Signal Voltage Gain AVO RL = 2 kΩ, −10 V ≤ VO ≤ 10 V 150 1000 V/mV RL = 2 kΩ, −40°C ≤ TA ≤ +125°C 75 V/mV Offset Voltage Drift E Grade ΔVOS/ΔT 0.2 2.00 μV/°C Bias Current Drift ΔVB/ΔT 150 pA/°C OUTPUT CHARACTERISTICS Output Voltage High VOH IL = 1.0 mA 14.8 V Output Voltage Low VOL IL = 1.0 mA −14.875 V Output Current IOUT ±10 mA POWER SUPPLY Power Supply Rejection Ratio PSRR VS = ±2.0 V to ±18 V, −40°C ≤ TA ≤ +125°C 90 dB Supply Current/Amplifier ISY VO = 0 V, −40°C ≤ TA ≤ +125°C 2.0 mA Supply Current/Amplifier ISY VS = ±18 V, −40°C ≤ TA ≤ +125°C 2.25 mA DYNAMIC PERFORMANCE Slew Rate SR RL = 2 kΩ 2.4 4.0 V/µs Full-Power Bandwidth BWp 1% distortion, RL = 2 kΩ, VO = 29 V p-p 35 kHz Settling Time tS To 0.01%, 10 V step 4 µs Gain Bandwidth Product GBP 4.25 MHz Phase Margin ΦM 50 Degrees NOISE PERFORMANCE Voltage Noise en p-p 0.1 Hz to 10 Hz 0.3 µV p-p Voltage Noise Density en f = 1 kHz 3.9 nV/√Hz Current Noise Density in 0.4 pA/√Hz 1 Input offset voltage measurements are performed by automated test equipment approximately 0.5 seconds after application of power. Rev. J | Page 5 of 24 Document Outline Features Applications General Description Pin Configurations Table of Contents Revision History Specifications Electrical Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Applications Information Functional Description Input Overvoltage Protection Output Phase Reversal Designing Low Noise Circuits in Single-Supply Applications Overdrive Recovery Single-Supply, 3 V Instrumentation Amplifier 2.5 V Reference from a 3 V Supply 5 V Only, 12-Bit DAC Swings Rail-to-Rail High-Side Current Monitor Capacitive Load Drive Capability Low Dropout Regulator with Current Limiting 3 V, 50 Hz/60 Hz Active Notch Filter with False Ground Outline Dimensions Ordering Guide
