Datasheet OP184, OP284, OP484 (Analog Devices) - 6
ОписаниеSingle-Supply Rail-to-Rail Input/Output Operational Amplifier
Страниц / Страница24 / 6 — OP184/OP284/OP484. ABSOLUTE MAXIMUM RATINGS. Table 5. THERMAL RESISTANCE. …
ВерсияJ
Формат / Размер файлаPDF / 685 Кб
OP184/OP284/OP484. ABSOLUTE MAXIMUM RATINGS. Table 5. THERMAL RESISTANCE. Parameter. Rating. Table 6. Thermal Resistance
OP184/OP284/OP484 ABSOLUTE MAXIMUM RATINGS Table 5 THERMAL RESISTANCE Parameter Rating Table 6 Thermal Resistance
37 предложений от 22 поставщиков
Зенер
Россия и страны ТС
OP484FSZ-REEL7
от 732 ₽
OP484FSZ
1 386 ₽
ЗУМ-СМД
OP484FSZ
1 486 ₽
OP484FSZ-REEL7
Ruimeng предлагает удачную замену популярной микросхеме Axx1248 – 24-битный Σ-Δ АЦП MS5148T
link to page 6
OP184/OP284/OP484 ABSOLUTE MAXIMUM RATINGS Table 5. THERMAL RESISTANCE Parameter Rating
θ Supply Voltage ±18 V JA is specified for the worst-case conditions; that is, θJA is specified for a device in socket for PDIP. θ Input Voltage ±18 V JA is specified for a device soldered in the circuit board for SOIC packages. Differential Input Voltage1 ±0.6 V Output Short-Circuit Duration to GND Indefinite
Storage Temperature Range
Package Type θJA θJC Unit
P-Suffix, S-Suffix Packages −65°C to +150°C 8-Lead PDIP (P-Suffix) 103 43 °C/W Operating Temperature Range 8-Lead SOIC (S-Suffix) 158 43 °C/W OP184/OP284/OP484E/OP484F −40°C to +125°C 14-Lead PDIP (P-Suffix) 83 39 °C/W Junction Temperature Range 14-Lead SOIC (S-Suffix) 92 27 °C/W P-Suffix, S-Suffix Packages −65°C to +150°C Lead Temperature 300°C (Soldering 60 sec)
ESD CAUTION
1 For input voltages greater than 0.6 V, the input current should be limited to less than 5 mA to prevent degradation or destruction of the input devices. Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress rating only; functional operation of the device at these or any other conditions above those indicated in the operational section of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Absolute maximum ratings apply to both DICE and packaged parts, unless otherwise noted.
VCC RB1 R3 R4 QB6 QB5 RB3 RB4 R11 TP Q12 Q16 Q17 Q11 JB1 Q8 QL1 Q7 QB9 Q1 Q3 Q4 Q2 QB10 –IN +IN CC2 Q10 Q9 OUT QL2 Q5 C O Q6 C FF R6 QB2 CB1 N+ Q18 QB3 M P+ RB2 QB4 R7 Q14 Q15 QB7 Q13 QB1 QB8 R1 R2 CC1 R5 R8 R9 R10
004
JB2 VEE
00293- Figure 4. Simplified Schematic Rev. J | Page 6 of 24 Document Outline Features Applications General Description Pin Configurations Table of Contents Revision History Specifications Electrical Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Applications Information Functional Description Input Overvoltage Protection Output Phase Reversal Designing Low Noise Circuits in Single-Supply Applications Overdrive Recovery Single-Supply, 3 V Instrumentation Amplifier 2.5 V Reference from a 3 V Supply 5 V Only, 12-Bit DAC Swings Rail-to-Rail High-Side Current Monitor Capacitive Load Drive Capability Low Dropout Regulator with Current Limiting 3 V, 50 Hz/60 Hz Active Notch Filter with False Ground Outline Dimensions Ordering Guide
