Оптопары и оптореле Megawin
Datasheet OP184, OP284, OP484 (Analog Devices) - 7
ОписаниеSingle-Supply Rail-to-Rail Input/Output Operational Amplifier
Страниц / Страница24 / 7 — OP184/OP284/OP484. TYPICAL PERFORMANCE CHARACTERISTICS. 300. VS = 3V. …
ВерсияJ
Формат / Размер файлаPDF / 685 Кб
OP184/OP284/OP484. TYPICAL PERFORMANCE CHARACTERISTICS. 300. VS = 3V. 270. TA = 25°C. S = 5V. –40°C ≤ T. CM = 1.5V. A ≤ +125°C. 250. 240. 210
OP184/OP284/OP484 TYPICAL PERFORMANCE CHARACTERISTICS 300 VS = 3V 270 TA = 25°C S = 5V –40°C ≤ T CM = 1.5V A ≤ +125°C 250 240 210
30 предложений от 15 поставщиков
Зенер
Россия и страны ТС
OP484FSZ-REEL7
от 732 ₽
OP484FSZ-REEL7
от 1 642 ₽
OP484FSZ-REEL7
5 119 ₽
SUV System
OP484FSZ-REEL7
Ruimeng предлагает удачную замену популярной микросхеме Axx1248 – 24-битный Σ-Δ АЦП MS5148T
OP184/OP284/OP484 TYPICAL PERFORMANCE CHARACTERISTICS 300 300 VS = 3V V 270 TA = 25°C S = 5V V –40°C ≤ T CM = 1.5V A ≤ +125°C 250 240 210 200 180 TITY TITY N 150 N 150 A A QU 120 QU 100 90 60 50 30
005 008
0
00293-
0
00293-
–100 –75 –50 –25 0 25 50 75 100 0 0.25 0.50 0.75 1.00 1.25 1.50 INPUT OFFSET VOLTAGE (µV) OFFSET VOLTAGE DRIFT, TCVOS (µV/°C)
Figure 5. Input Offset Voltage Distribution Figure 8. Input Offset Voltage Drift Distribution
300 300 VS = 5V VS = ±15V 270 TA = 25°C V –40°C ≤ TA ≤ +125°C CM = 2.5V 250 240 210 200 180 TITY TITY N 150 N 150 A A QU 120 QU 100 90 60 50 30
006 009 00293-
00293-
Figure 6. Input Offset Voltage Distribution Figure 9. Input Offset Voltage Drift Distribution
200 –40 VS = ±15V T VCM = VS/2 A = 25°C 175 –45 150 –50 A) n ( 125 NT –55 VS = +5V TITY N 100 –60 A CURRE QU AS 75 –65 BI UT 50 –70 INP VS = ±15V 25 –75
007 010 00293-
0 –80
00293-
–125 –100 –75 –50 –25 0 25 50 75 100 125 –40 25 85 125 INPUT OFFSET VOLTAGE (µV) TEMPERATURE (°C)
Figure 7. Input Offset Voltage Distribution Figure 10. Bias Current vs. Temperature Rev. J | Page 7 of 24 Document Outline Features Applications General Description Pin Configurations Table of Contents Revision History Specifications Electrical Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Applications Information Functional Description Input Overvoltage Protection Output Phase Reversal Designing Low Noise Circuits in Single-Supply Applications Overdrive Recovery Single-Supply, 3 V Instrumentation Amplifier 2.5 V Reference from a 3 V Supply 5 V Only, 12-Bit DAC Swings Rail-to-Rail High-Side Current Monitor Capacitive Load Drive Capability Low Dropout Regulator with Current Limiting 3 V, 50 Hz/60 Hz Active Notch Filter with False Ground Outline Dimensions Ordering Guide
