Datasheet AD8044 (Analog Devices) - 5
ОписаниеQuad 150 MHz Rail-to-Rail Amplifier
Страниц / Страница18 / 5 — SPECIFICATIONS (@ T. AD8044. A = +25. C, VS = +3 V, RL = 2 k. to 1.5 V, …
ВерсияB
Формат / Размер файлаPDF / 322 Кб
SPECIFICATIONS (@ T. AD8044. A = +25. C, VS = +3 V, RL = 2 k. to 1.5 V, unless otherwise noted.). AD8044A. Parameter. Conditions. Min
SPECIFICATIONS (@ T AD8044 A = +25 C, VS = +3 V, RL = 2 k to 1.5 V, unless otherwise noted.) AD8044A Parameter Conditions Min
to 1.5 V, unless otherwise noted.) AD8044A Parameter Conditions Min Typ Max Units
DYNAMIC PERFORMANCE –3 dB Small Signal Bandwidth, VO < 0.5 V p-p G = +1 80 135 MHz Bandwidth for 0.1 dB Flatness G = +2, RL = 150 W 10 MHz Slew Rate G = –1, VO = 2 V Step 110 150 V/ms Full Power Response VO = 2 V p-p 22 MHz Settling Time to 1% G = –1, VO = 2 V Step 35 ns Settling Time to 0.1% 55 ns NOISE/DISTORTION PERFORMANCE Total Harmonic Distortion fC = 5 MHz, VO = 2 V p-p, G = –1, RL = 100 W –48 dB Input Voltage Noise f = 10 kHz 16 nV/÷Hz Input Current Noise f = 10 kHz 600 fA/÷Hz Differential Gain Error (NTSC) G = +2, RL = 150 W to 1.5 V, Input VCM = 0.5 V 0.13 % Differential Phase Error (NTSC) G = +2, RL = 150 W to 1.5 V, Input VCM = 0.5 V 0.3 Degrees Crosstalk f = 5 MHz, RL = 1 kW, G = +2 –60 dB DC PERFORMANCE Input Offset Voltage 1.5 5.5 mV TMIN–TMAX 7.5 mV Offset Drift 8 mV/∞C Input Bias Current 2 4.5 mA TMIN–TMAX 4.5 mA Input Offset Current 0.2 1.2 mA Open-Loop Gain RL = 1 kW 80 92 dB TMIN–TMAX 88 dB INPUT CHARACTERISTICS Input Resistance 225 kW Input Capacitance 1.6 pF Input Common-Mode Voltage Range –0.2 to 2 V Common-Mode Rejection Ratio VCM = 0 V to 1.5 V 76 90 dB OUTPUT CHARACTERISTICS Output Voltage Swing RL = 10 kW to 1.5 V 0.025 to 2.98 V Output Voltage Swing: RL = 1 kW to 1.5 V 0.17 to 2.82 0.06 to 2.93 V Output Voltage Swing: RL = 150 W to 1.5 V 0.35 to 2.55 0.15 to 2.75 V Output Current TMIN–TMAX, VOUT = 0.5 V to 2.5 V 25 mA Short Circuit Current Sourcing 30 mA Sinking 50 mA Capacitive Load Drive G = +2 35 pF POWER SUPPLY Operating Range 3 12 V Quiescent Current 10.5 12.5 mA Power Supply Rejection Ratio VS = 0, +3 V, +0.5 V 70 80 dB OPERATING TEMPERATURE RANGE 0 +70 ∞C Specifications subject to change without notice. REV. B –3– Document Outline FEATURES APPLICATIONS PRODUCT DESCRIPTION CONNECTION DIAGRAM SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION ORDERING GUIDE Typical Performance Characteristics Overdrive Recovery Circuit Description Driving Capacitance Loads APPLICATIONS RGB Buffer Active Filters Layout Considerations OUTLINE DIMENSIONS Revision History
