Datasheet OP191, OP291, OP491 (Analog Devices) - 7
ОписаниеMicropower Single-Supply Rail-to-Rail Input/Output Op Amps
Страниц / Страница24 / 7 — OP191/OP291/OP491. ABSOLUTE MAXIMUM RATINGS Table 4. THERMAL RESISTANCE. …
ВерсияE
Формат / Размер файлаPDF / 569 Кб
OP191/OP291/OP491. ABSOLUTE MAXIMUM RATINGS Table 4. THERMAL RESISTANCE. Parameter Rating. Table 5. Thermal Resistance
OP191/OP291/OP491 ABSOLUTE MAXIMUM RATINGS Table 4 THERMAL RESISTANCE Parameter Rating Table 5 Thermal Resistance
59 предложений от 25 поставщиков
727GS
OP291GSZ-REEL7
от 15 ₽
OP291GSZ-REEL7
167 ₽
Элевика
OP291GSZ-REEL7
554 ₽
Элрус
OP291GSZ-REEL7
554 ₽
OP191/OP291/OP491 ABSOLUTE MAXIMUM RATINGS Table 4. THERMAL RESISTANCE Parameter Rating
θ Supply Voltage 16 V JA is specified for the worst-case conditions; that is, θJA is specified for device in socket for PDIP packages; θ Input Voltage GND to (V JA is specified S + 10 V) for device soldered in circuit board for TSSOP and SOIC Differential Input Voltage 7 V packages. Output Short-Circuit Duration to GND Indefinite Storage Temperature Range
N, R, RU Packages −65°C to +150°C
Package Type θJA θJC Unit
Operating Temperature Range 8-Lead SOIC (R) 158 43 °C/W OP191G/OP291G/OP491G −40°C to +125°C 14-Lead PDIP (N) 76 33 °C/W Junction Temperature Range 14-Lead SOIC (R) 120 36 °C/W N, R, RU Packages −65°C to +150°C 14-Lead TSSOP (RU) 180 35 °C/W Lead Temperature (Soldering, 60 sec) 300°C Stresses above those listed under Absolute Maximum Ratings
ESD CAUTION
may cause permanent damage to the device. This is a stress rating only; functional operation of the device at these or any other conditions above those indicated in the operational section of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Absolute maximum ratings apply to both DICE and packaged parts, unless otherwise noted. Rev. E | Page 7 of 24 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATIONS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION INPUT OVERVOLTAGE PROTECTION OUTPUT VOLTAGE PHASE REVERSAL OVERDRIVE RECOVERY APPLICATIONS INFORMATION SINGLE 3 V SUPPLY, INSTRUMENTATION AMPLIFIER SINGLE-SUPPLY RTD AMPLIFIER A 2.5 V REFERENCE FROM A 3 V SUPPLY 5 V ONLY, 12-BIT DAC SWINGS RAIL-TO-RAIL A HIGH-SIDE CURRENT MONITOR A 3 V, COLD JUNCTION COMPENSATED THERMOCOUPLE AMPLIFIER SINGLE-SUPPLY, DIRECT ACCESS ARRANGEMENT FOR MODEMS 3 V, 50 HZ/60 HZ ACTIVE NOTCH FILTER WITH FALSE GROUND SINGLE-SUPPLY, HALF-WAVE, AND FULL-WAVE RECTIFIERS OUTLINE DIMENSIONS ORDERING GUIDE
