Datasheet OP285 (Analog Devices) - 6
ОписаниеDual 9 MHz Precision Operational Amplifier
Страниц / Страница17 / 6 — Typical Performance Characteristics–OP285. 100. A = +1. MHz. VCL. –VOM. …
ВерсияC
Формат / Размер файлаPDF / 242 Кб
Typical Performance Characteristics–OP285. 100. A = +1. MHz. VCL. –VOM. NEGATIVE EDGE. Volts 12. Degrees. POSITIVE EDGE. +VOM. GBW. OVERSHOOT
Typical Performance Characteristics–OP285 100 A = +1 MHz VCL –VOM NEGATIVE EDGE Volts 12 Degrees POSITIVE EDGE +VOM GBW OVERSHOOT
14 предложений от 14 поставщиков
IC OPAMP GP 2 CIRCUIT 8SOIC. General Purpose Amplifier 2 Circuit 8-SOIC. Linear - Amplifiers - Instrumentation, OP Amps, Buffer Amps...
OP285GS-REEL
208 ₽
OP285GS-REEL7
315 ₽
OP285GS-REEL7
348 ₽
OP285GS-REEL7
Typical Performance Characteristics–OP285 11 65 100 16 90 14 A = +1 MHz VCL
–VOM
80 NEGATIVE EDGE 10 60 Volts 12 ø M 70 % 10 Degrees 60 A = +1 9 VCL 55 8 50 POSITIVE EDGE +VOM GBW 40 6 OVERSHOOT 30 V 8 50 S = 15V 4 TA = 25 C PHASE MARGIN R 20 L = 2k V V S = 15V IN = 100mV p-p 2 MAXIMUM OUTPUT SWING GAIN BANDWIDTH PRODUCT 10 7 40 0 0 –50 –25 0 25 50 75 100 0 100 200 300 400 500 100 1k 10k TEMPERATURE – C LOAD RESISTANCE – LOAD CAPACITANCE – pF
TPC 10. Gain Bandwidth Product, TPC 11. Small-Signal Overshoot vs.| TPC 12. Maximum Output Voltage Phase Margin vs. Temperature Load Capacitance vs. Load Resistance
30 120 5.0 110 VS = 15V 25 mA V 100 4.5 90 20 mA SINK TA = +85 C 80 15 4.0 70 TA = +25 C 60 10 T T A = 25 C A = –40 C 50 VS = 15V A 3.5 VCL = +1 40 5 SUPPLY CURRENT MAXIMUM OUTPUT SWING R SOURCE L = 2k 30 ABSOLUTE OUTPUT CURRENT 0 3.0 20 1k 10k 100k 1M 10M –50 –25 0 25 50 75 100 0 5 10 15 25 FREQUENCY – Hz SUPPLY VOLTAGE – V TEMPERATURE – C
TPC 13. Maximum Output Swing TPC 14. Supply Current vs. TPC 15. Short Circuit Current vs. vs. Frequency Supply Voltage Temperature
300 5 250 VS = 15V VS = 15V –40 C TA +85 C 250 Hz T 402 OP AMPS A = 25 C 200 nA 4 pA/ 200 3 150 150 UNITS 2 100 100 INPUT BIAS CURRENT 50 50 1 CURRENT NOISE DENSITY 0 0 –50 –25 0 25 50 75 100 10 100 1k 100k 0 1 2 3 4 5 6 7 8 9 10 TEMPERATURE – C T FREQUENCY – Hz C VOS – V/ C
TPC 16. Input Bias Current vs. TPC 17. Current Noise Density vs. TPC 18. tC VOS Distribution Temperature Frequency REV. A –5–
