Datasheet OP282, OP482 (Analog Devices) - 9
ОписаниеDual/Quad, Low Power, High Speed JFET Operational Amplifiers
Страниц / Страница16 / 9 — Data Sheet. OP282/OP482. 1000. S = ±15V. CM = 0V. A = 25°C. 100. p (. …
ВерсияI
Формат / Размер файлаPDF / 318 Кб
Data Sheet. OP282/OP482. 1000. S = ±15V. CM = 0V. A = 25°C. 100. p (. CURRE. INP. 1.0. 0.1. –75. –50. –25. 125. –15. –10. TEMPERATURE (°C)
Data Sheet OP282/OP482 1000 S = ±15V CM = 0V A = 25°C 100 p ( CURRE INP 1.0 0.1 –75 –50 –25 125 –15 –10 TEMPERATURE (°C)
14 предложений от 12 поставщиков
OP482ACBZ-R7
65 ₽
ЧипСити
OP482ACBZ-R7
354 ₽
OP482ACBZ-R7
OP482ACBZ-R7
Data Sheet OP282/OP482 1000 1000 V V S = ±15V S = ±15V V T CM = 0V A = 25°C A) 100 p A) 100 ( p ( NT NT 10 CURRE 10 CURRE AS AS BI BI UT UT INP 1.0 INP 1
029 032
0.1
00301-
0.1
00301-
–75 –50 –25 0 25 50 75 100 125 –15 –10 –5 0 5 10 15 TEMPERATURE (°C) COMMON-MODE VOLTAGE (V)
Figure 30. OP482 Input Bias Current vs. Temperature Figure 33. OP482 Input Bias Current vs. Common-Mode Voltage
60 5.0 1.15 V T S = ±15V A = 25°C RL = 10kΩ ) ) 1.10 Hz I SY M ( 55 rees) 4.5 ( GBW NT Deg 1.05 DUCT IN ( RO ØM CURRE Y ARG 50 4.0 H P L 1.00 M PP E IDT HAS 0.95 P IVE SU T 45 3.5 A N BANDW L AI 0.90 G RE
033
40 3.0 0.85
00301- 030
–75 –50 –25 0 25 50 75 100 125 0 ±5 ±10 ±15 ±20 TEMPERATURE (°C)
00301-
SUPPLY VOLTAGE (V)
Figure 31. OP482 Phase Margin and Gain Bandwidth Product vs. Figure 34. OP482 Relative Supply Current vs. Supply Voltage Temperature
80 20 VS = ±15V RL = 10kΩ TA = 25°C TA = 25°C 70 15 ) √HzV/ 60 (V) 10 G Y (n IN T 50 5 SI EN E SW G 40 A 0 ISE D LT O O 30 –5 T V E N U G A TP 20 T –10 L OU VO 10 –15
031 034
0
00301-
–20
00301-
10 100 1k 10k 0 ±5 ±10 ±15 ±20 FREQUENCY (Hz) SUPPLY VOLTAGE (V)
Figure 32. OP482 Voltage Noise Density vs. Frequency Figure 35. OP482 Output Voltage Swing vs. Supply Voltage Rev. I | Page 9 of 16 Document Outline Features Applications General Description Pin Connections Table of Contents Revision History Specifications Electrical Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Applications Information High-Side Signal Conditioning Phase Inversion Active Filters Programmable State Variable Filter Outline Dimensions Ordering Guide
