Datasheet OP297 (Analog Devices) - 5
ОписаниеLow Bias Current Precision (Dual) Operational Amplifier
Страниц / Страница17 / 5 — OP297. ABSOLUTE MAXIMUM RATINGS Table 3. THERMAL RESISTANCE. Parameter …
ВерсияG
Формат / Размер файлаPDF / 300 Кб
OP297. ABSOLUTE MAXIMUM RATINGS Table 3. THERMAL RESISTANCE. Parameter Rating. Table 4. Thermal Resistance. Package Type. θJC Unit
OP297 ABSOLUTE MAXIMUM RATINGS Table 3 THERMAL RESISTANCE Parameter Rating Table 4 Thermal Resistance Package Type θJC Unit
14 предложений от 14 поставщиков
IC OPAMP GP 2 CIRCUIT 8SOIC. General Purpose Amplifier 2 Circuit 8-SOIC. Linear - Amplifiers - Instrumentation, OP Amps, Buffer Amps...
ЧипСити
OP297GS-REEL7
126 ₽
OP297GS-REEL7
Рутоника
OP297GS-REEL7
OP297GS-REEL7
link to page 5 link to page 5
OP297 ABSOLUTE MAXIMUM RATINGS Table 3. THERMAL RESISTANCE Parameter Rating
θJA is specified for worst-case mounting conditions, that is, θJA Supply Voltage ±20 V is specified for device in socket for CERDIP and PDIP pack- Input Voltage1 ±20 V ages; θJA is specified for device soldered to printed circuit board Differential Input Voltage1 40 V for the SOIC package. Output Short-Circuit Duration Indefinite
Storage Temperature Range
Package Type θ
Z-Suffix −65°C to +175°C
JA θJC Unit
P-Suffix, S-Suffix −65°C to +150°C 8-Lead CERDIP (Z-Suffix) 134 12 °C/W Operating Temperature Range 8-Lead PDIP (P-Suffix) 96 37 °C/W OP297E (Z-Suffix) −40°C to +85°C 8-Lead SOIC (S-Suffix) 150 41 °C/W OP297F, OP297G (P-Suffix, S-Suffix) −40°C to +85°C Junction Temperature
ESD CAUTION
Z-Suffix −65°C to +175°C P-Suffix, S-Suffix −65°C to +150°C Lead Temperature (Soldering, 60 sec) 300°C 1 For supply voltages less than ±20 V, the absolute maximum input voltage is equal to the supply voltage. Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress rating only; functional operation of the device at these or any other conditions above those indicated in the operational section of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability.
– 1/2 OP297 V1 20V p-p @ 10Hz + 2kΩ 50kΩ 50Ω – 1/2 OP297 V2 +
4 00
V1
0-
CHANNEL SEPARATION = 20 log
30
V2/10000
00 Figure 4. Channel Separation Test Circuit Rev. G | Page 4 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION AC PERFORMANCE GUARDING AND SHIELDING OPEN-LOOP GAIN LINEARITY APPLICATION CIRCUITS PRECISION ABSOLUTE VALUE AMPLIFIER PRECISION CURRENT PUMP PRECISION POSITIVE PEAK DETECTOR SIMPLE BRIDGE CONDITIONING AMPLIFIER NONLINEAR CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
