Datasheet AD847 (Analog Devices) - 7
ОписаниеHigh Speed, Low Power Monolithic Op Amp
Страниц / Страница14 / 7 — AD847. Typical Characteristics (@ +25. C and VS =. 15 V, unless otherwise …
ВерсияF
Формат / Размер файлаPDF / 281 Кб
AD847. Typical Characteristics (@ +25. C and VS =. 15 V, unless otherwise noted). Volts 15. +VIN. +VOUT. –VIN. –VOUT
AD847 Typical Characteristics (@ +25 C and VS = 15 V, unless otherwise noted) Volts 15 +VIN +VOUT –VIN –VOUT
Микросхема Буферный усилитель, Ic Opamp Gp 50MHz Lp 32mA 8soic - Ad847ar-Reel7
AD847AR-REEL7
339 ₽
ЧипСити
AD847AR-REEL7
475 ₽
AD847AR-REEL7
AD847AR-REEL7
8
C and VS =
6
15 V, unless otherwise noted) 20 20
Volts 15 15 +VIN +VOUT 10 10 –VIN –VOUT 5 5 OUTPUT VOLTAGE SWING – Volts R = 500 LOAD
INPUT COMMON-MODE RANGE – 0 0 0 5 10 15 20 0 5 10 15 20 SUPPLY VOLTAGE –
Volts SUPPLY VOLTAGE –
Volts
Figure 1. Input Common-Mode Range vs. Supply Voltage Figure 2. Output Voltage Swing vs. Supply Voltage
30 6 25 5.5 20
15 V SUPPLIES 15 5 10 4.5
QUIESCENT CURRENT – mA 5V SUPPLIES 5 OUTPUT VOLTAGE SWING – Volts p-p 0 4 10 100 1k 10k 0 5 10 15 20 LOAD RESISTANCE –
SUPPLY VOLTAGE –
Volts
Figure 3. Output Voltage Swing vs. Load Resistance Figure 4. Quiescent Current vs. Supply Voltage
5 100
µ
A 10
4 V =
5V S 1 3 INPUT BIAS CURRENT – OUTPUT IMPEDANCE – 0.1 2 0.01 –60 –40 –20 0 20 40 60 80 100 120 140 10k 100k 1M 10M 100M TEMPERATURE –
C FREQUENCY – Hz
Figure 5. Input Bias Current vs. Temperature Figure 6. Output Impedance vs. Frequency REV. F –5–
