Datasheet OP07 (Analog Devices) - 4
ОписаниеUltralow Offset Voltage Op Amp
Страниц / Страница17 / 4 — Data Sheet. OP07. SPECIFICATIONS OP07E ELECTRICAL CHARACTERISTICS. Table …
ВерсияG
Формат / Размер файлаPDF / 254 Кб
Data Sheet. OP07. SPECIFICATIONS OP07E ELECTRICAL CHARACTERISTICS. Table 1. Parameter. Symbol. Conditions. Min. Typ. Max Unit. TA = 25°C
Data Sheet OP07 SPECIFICATIONS OP07E ELECTRICAL CHARACTERISTICS Table 1 Parameter Symbol Conditions Min Typ Max Unit TA = 25°C
Микросхема Буферный усилитель, IC OPAMP GP 600kHz 8DIP
ЧипСити
OP07DN8
136 ₽
OP07DN8
OP07DN8
727GS
OP07DN8
link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 5
VS = ±15 V, unless otherwise noted.
Table 1. Parameter Symbol Conditions Min Typ Max Unit
INPUT CHARACTERISTICS
TA = 25°C
Input Offset Voltage1 VOS 30 75 μV Long-Term VOS Stability2 VOS/Time 0.3 1.5 μV/Month Input Offset Current IOS 0.5 3.8 nA Input Bias Current IB ±1.2 ±4.0 nA Input Noise Voltage en p-p 0.1 Hz to 10 Hz3 0.35 0.6 μV p-p Input Noise Voltage Density en fO = 10 Hz 10.3 18.0 nV/√Hz fO = 100 Hz3 10.0 13.0 nV/√Hz fO = 1 kHz 9.6 11.0 nV/√Hz Input Noise Current In p-p 14 30 pA p-p Input Noise Current Density In fO = 10 Hz 0.32 0.80 pA/√Hz fO = 100 Hz3 0.14 0.23 pA/√Hz fO = 1 kHz 0.12 0.17 pA/√Hz Input Resistance, Differential Mode4 RIN 15 50 MΩ Input Resistance, Common Mode RINCM 160 GΩ Input Voltage Range IVR ±13 ±14 V Common-Mode Rejection Ratio CMRR VCM = ±13 V 106 123 dB Power Supply Rejection Ratio PSRR VS = ±3 V to ±18 V 5 20 μV/V Large Signal Voltage Gain AVO RL ≥ 2 kΩ, VO = ±10 V 200 500 V/mV RL ≥ 500 Ω, VO = ±0.5 V, VS = ±3 V4 150 400 V/mV
0°C ≤ TA ≤ 70°C
Input Offset Voltage1 VOS 45 130 μV Voltage Drift Without External Trim4 TCVOS 0.3 1.3 μV/°C Voltage Drift with External Trim3 TCVOSN RP = 20 kΩ 0.3 1.3 μV/°C Input Offset Current IOS 0.9 5.3 nA Input Offset Current Drift TCIOS 8 35 pA/°C Input Bias Current IB ±1.5 ±5.5 nA Input Bias Current Drift TCIB 13 35 pA/°C Input Voltage Range IVR ±13 ±13.5 V Common-Mode Rejection Ratio CMRR VCM = ±13 V 103 123 dB Power Supply Rejection Ratio PSRR VS = ±3 V to ±18 V 7 32 μV/V Large Signal Voltage Gain AVO RL ≥ 2 kΩ, VO = ±10 V 180 450 V/mV OUTPUT CHARACTERISTICS
TA = 25°C
Output Voltage Swing VO RL ≥ 10 kΩ ±12.5 ±13.0 V RL ≥ 2 kΩ ±12.0 ±12.8 V RL ≥ 1 kΩ ±10.5 ±12.0 V
0°C ≤ TA ≤ 70°C
Output Voltage Swing VO RL ≥ 2 kΩ ±12 ±12.6 V Rev. G | Page 3 of 16 Document Outline Features Applications General Description Pin Configuration Revision History Specifications OP07E Electrical Characteristics OP07C Electrical Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Typical Applications Applications Information Outline Dimensions Ordering Guide
