Datasheet OP07 (Analog Devices) - 8
ОписаниеUltralow Offset Voltage Op Amp
Страниц / Страница17 / 8 — Data Sheet. OP07. TYPICAL PERFORMANCE CHARACTERISTICS. 1000. 1.0. S = …
ВерсияG
Формат / Размер файлаPDF / 254 Кб
Data Sheet. OP07. TYPICAL PERFORMANCE CHARACTERISTICS. 1000. 1.0. S = ±15V. 900. TA = 25°C. 800. 0.8. 700. (V/. D T. 600. 0.6. RRE. 500. P G. O O. 400. 0.4. R RE
Data Sheet OP07 TYPICAL PERFORMANCE CHARACTERISTICS 1000 1.0 S = ±15V 900 TA = 25°C 800 0.8 700 (V/ D T 600 0.6 RRE 500 P G O O 400 0.4 R RE
27 предложений от 19 поставщиков
Контест
OP07CS8
128 ₽
OP07CS8#PBF
146 ₽
OP07CS8#TR
178 ₽
OP07CS8#TR
Data Sheet OP07 TYPICAL PERFORMANCE CHARACTERISTICS 1000 1.0 V ) V S = ±15V S = ±15V 900 mV TA = 25°C ( 800 UT 0.8 NP V) I 700 m O (V/ D T 600 IN 0.6 A RRE 500 E P G F O O 400 0.4 -L R RE 300 PEN RRO O E OP07C 200 0.2 UM IM 100 AX M OP07E 0 0 –75 –50 –25 0 25 50 75 100 125
003
100 1k 10k 100k
006
TEMPERATURE (°C) MATCHED OR UNMATCHED SOURCE RESISTANCE (Ω)
00316- 00316- Figure 3. Open-Loop Gain vs. Temperature Figure 6. Maximum Error vs. Source Resistance
30 1.2 V ) S = ±15V VS = ±15V TA = 25°C, TA = 70°C mV 0°C ≤ TA ≤ 70°C ( 25 1.0 UT UT ) NP I NP V µ O ( 20 N I 0.8 I D T E GE RRE 15 E OLTA 0.6 F THERMAL CHANG SHOCK E T V E RESPONSE R RE UT BAND 10 L 0.4 O OFFS RRO DEVICE IMMERSED E OP07C ABS IN 70°C OIL BATH UM 5 0.2 IM AX M OP07E 0 0 –20 0 20 40 60 80 100
004
100 1k 10k 100k
007
TIME (Seconds) MATCHED OR UNMATCHED SOURCE RESISTANCE (Ω)
00316- 00316- Figure 4. Offset Voltage Change due to Thermal Shock Figure 7. Maximum Error vs. Source Resistance
25 30 V AT |V S = ±15V DIFF| ≤ 1.0V, | IB | ≤ 7nA (OP07C) T A) V A = 25°C n S = ±15V ( T 20 A = 25°C 20 NT UT ) NP V µ N I ( 10 I CURRE E GE 15 AS BI OLTA 0 UT CHANG E T V 10 NP E I OP07C UT L –10 ING O OFFS OP07E RT E ABS 5 NV –20 NI NO 0 –30 0 1 2 3 4 5
005
–30 –20 –10 0 10 20 30
008
TIME AFTER SUPPLY TURN-ON (Minutes) DIFFERENTIAL INPUT VALUE (V)
00316- 00316- Figure 5. Warm-Up Drift Figure 8. Input Bias Current vs. Differential Input Voltage Rev. G | Page 7 of 16 Document Outline Features Applications General Description Pin Configuration Revision History Specifications OP07E Electrical Characteristics OP07C Electrical Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Typical Applications Applications Information Outline Dimensions Ordering Guide
