Datasheet LTC1286, LTC1298 (Analog Devices) - 5
ОписаниеMicropower Sampling 12-Bit A/D Converters In S0-8 Packages
Страниц / Страница24 / 5 — TYPICAL PERFORMANCE CHARACTERISTICS. Reference Current vs. Change in …
Формат / Размер файлаPDF / 299 Кб
TYPICAL PERFORMANCE CHARACTERISTICS. Reference Current vs. Change in Offset vs. Sample Rate (LTC1286)
TYPICAL PERFORMANCE CHARACTERISTICS Reference Current vs Change in Offset vs Sample Rate (LTC1286)
25 предложений от 17 поставщиков
IC ADC 12BIT SAR 8SOIC. 12 Bit Analog to Digital Converter 1 Input 1 SAR 8-SOIC. Data Acquisition - Analog to...
Зенер
Россия и страны ТС
LTC1286CS8#TRPBF
от 1 742 ₽
LTC1286CS8#TRPBF
SUV System
LTC1286CS8#TRPBF
Hi-Tech Circuit Group
LTC1286CS8#TRPBF
LTC1286/LTC1298
W U TYPICAL PERFORMANCE CHARACTERISTICS Reference Current vs Change in Offset vs Sample Rate (LTC1286) Reference Current vs Temperature Reference Voltage
100 95 3 T ) T 90 A = 25°C VCC = VREF = 5V A = 25°C VCC = 5V f REF V 94.5 SMPL = 12.5kHz CC = 5V 2.5 80 VREF = 5V fCLK = 200kHz fCLK = 200kHz µA) fCLK = 200kHz TA = 25°C fSMPL = 12.5kHz 70 94 2 60 50 93.5 1.5 40 93 1 30 REFERENCE CURRENT ( 20 REFERENCE CURRENT (µA) 92.5 0.5 10 CHANGE IN OFFSET (LSB = 1/4096 V 0 92 0 0 2 4 6 8 10 12 14 –55 –35 –15 5 25 45 65 85 105 125 1 1.5 2 2.5 3 3.5 4 4.5 5 FREQUENCY (kHz) TEMPERATURE (°C) REFERENCE VOLTAGE (V) LT1286/98 G06 LT1286/98 G07 LT1286/98 G08
Change In Linearity vs Change In Gain vs Change in Offset vs Temperature Reference Voltage Reference Voltage
0 – 0 .5 –10 TA = 25°C T – 0 .45 A = 25°C V –9 CC = 5V VCC = 5V -0.5 – 0 .4 fCLK = 200kHz –8 fCLK = 200kHz fSMPL = 12.5kHz fSMPL = 12.5kHz – 0 .35 –7 -1 – 0 .3 –6 1.5 – .25 –5 – 0 .2 –4 -2 – 0 .15 –3 CHANGE IN GAIN (LSB) CHANGE IN OFFSET (LSB) VCC = VREF = 5V CHANGE IN LINEARITY (LSB) – 0 .1 –2 -2.5 fCLK = 200kHz f – 0 .05 SMPL = fSMPL (MAX) –1 -3 0 0 1 1.5 2 2.5 3 3.5 4 4.5 5 -55 -35 -15 5 25 45 65 85 1 1.5 2 2.5 3 3.5 4 4.5 5 REFERENCE VOLTAGE (V) TEMPERATURE (°C) REFERENCE VOLTAGE (V) LT1286/98 G10 LT1286/98 G09 LT1286/98 G11
Peak-to-Peak ADC Noise vs Effective Bits and S/(N + D) Reference Voltage Differential Nonlinearity vs Code vs Input Frequency
2 1.0 12 74 TA = 25°C 11 68 0.80 VCC = 5V 10 62 fCLK = 200kHz 0.60 1.5 9 56 0.40 8 50 0.20 7 44 1 0.00 6 38 –0.20 5 ADC NOISE IN LBSs –0.40 4 0.5 3 TA = 25°C –0.60 V 2 CC = 5V –0.80 EFFECTIVE NUMBER OF BITS (ENOBs) fCLK = 200kHz 1 DIFFERENTIAL NONLINEARITY ERROR (LBS) fSMPL = 12.5kHz 0 –1.0 0 1 2 3 4 5 0 2048 4096 1 10 100 1000 REFERENCE VOLTAGE (V) CODE INPUT FREQUENCY (kHz) LT1286/98 G15 LTC 1286/98 G20 5
