Datasheet LTC1286, LTC1298 (Analog Devices) - 7
ОписаниеMicropower Sampling 12-Bit A/D Converters In S0-8 Packages
Страниц / Страница24 / 7 — TYPICAL PERFORMANCE CHARACTERISTICS. Minimum Clock Frequency. Digital …
Формат / Размер файлаPDF / 299 Кб
TYPICAL PERFORMANCE CHARACTERISTICS. Minimum Clock Frequency. Digital Input Logic Threshold. Input Channel Leakage Current
TYPICAL PERFORMANCE CHARACTERISTICS Minimum Clock Frequency Digital Input Logic Threshold Input Channel Leakage Current
25 предложений от 18 поставщиков
Микросхема Преобразователь AD, Single Channel Single ADC SAR 12.5KSPS 12Bit Serial 8Pin PDIP N
LTC1286IN8#PBF
360 ₽
ЧипСити
LTC1286IN8#PBF
538 ₽
Рутоника
LTC1286IN8#PBF
691 ₽
727GS
LTC1286IN8#PBF
LTC1286/LTC1298
W U TYPICAL PERFORMANCE CHARACTERISTICS Minimum Clock Frequency Digital Input Logic Threshold Input Channel Leakage Current for 0.1 LSB Error vs Temperature vs Supply Voltage vs Temperature
200 3 1000 VCC = VREF = 5V TA = 25°C VCC = 5V VREF = 5V 100 150 10 100 2 ON CHANNEL 1 CLOCK FREQUENCY (kHz) 50 LEAKAGE CURRENT (nA) OFF CHANNEL 0.1 DIGITAL LOGIC THRESHOLD VOLTAGE (V) 0 1 0.01 –55 –35 –15 5 25 45 65 85 3 4 5 6 7 8 9 – 60 –40 –20 0 20 40 60 80 100 120 140 TEMPERATURE (°C) SUPPLY VOLTAGE (V) TEMPERATURE (°C) LT1286/98 • G14 LTC 1286/98 G17 1196/98 G19
U U U PIN FUNCTIONS LTC1286 LTC1298 VREF (Pin 1):
Reference Input. The reference input defines
CS/SHDN (Pin 1):
Chip Select Input. A logic low on this the span of the A/D converter. input enables the LTC1298. A logic high on this input disables and powers down the LTC1298.
IN+ (Pin 2):
Positive Analog Input.
CH0 (Pin 2):
Analog Input.
IN – (Pin 3):
Negative Analog Input.
CH1 (Pin 3):
Analog Input.
GND (Pin 4):
Analog Ground. GND should be tied directly to an analog ground plane.
GND (Pin 4):
CS/SHDN (Pin 5):
Chip Select Input. A logic low on this input enables the LTC1286. A logic high on this input
DIN (Pin 5):
Digital Data Input. The multiplexer address is disables and powers down the LTC1286. shifted into this input.
DOUT (Pin 6):
Digital Data Output. The A/D conversion
DOUT (Pin 6):
Digital Data Output. The A/D conversion result is shifted out of this output. result is shifted out of this output.
CLK (Pin 7):
Shift Clock. This clock synchronizes the serial
CLK (Pin 7):
Shift Clock. This clock synchronizes the data transfer and determines conversion speed. serial data transfer and determines conversion speed.
VCC (Pin 8):
Power Supply Voltage. This pin provides
VCC/VREF (Pin 8):
Power Supply and Reference Voltage. power to the A/D converter. It must be kept free of noise This pin provides power and defines the span of the A/D and ripple by bypassing directly to the analog ground converter. It must be kept free of noise and ripple by plane. bypassing directly to the analog ground plane. 7
