Datasheet LTC1401 (Analog Devices) - 3
ОписаниеComplete SO-8, 12-Bit, 200ksps ADC with Shutdown
Страниц / Страница20 / 3 — CO VERTER CH. ARA TERISTICS The. denotes specifications which apply over …
Формат / Размер файлаPDF / 254 Кб
CO VERTER CH. ARA TERISTICS The. denotes specifications which apply over the full operating temperature
CO VERTER CH ARA TERISTICS The denotes specifications which apply over the full operating temperature
13 предложений от 13 поставщиков
IC ADC 12BIT SAR 8SOIC. 12 Bit Analog to Digital Converter 1 Input 1 SAR 8-SOIC. Data Acquisition - Analog to...
LTC1401IS8#TRPBF
410 ₽
LTC1401IS8#TRPBF
570 ₽
727GS
LTC1401IS8#TRPBF
Hi-Tech Circuit Group
LTC1401IS8#TRPBF
LTC1401
U CO VERTER CH C ARA TERISTICS The
denotes specifications which apply over the full operating temperature range, unless otherwise noted specifications are at TA = 25
C. With internal reference VCC = 3V, fSAMPLE = 200kHz, tr = tf = 5ns, unless otherwise specified. PARAMETER CONDITIONS MIN TYP MAX UNITS
Resolution (No Missing Codes) ● 12 Bits Integral Linearity Error (Note 6) ● ±1 LSB Differential Linearity Error ● ±1 LSB Offset Error ±6 LSB ● ±8 LSB Full-Scale Error ±15 LSB Full-Scale Tempco IOUT(REF) = 0 ● ±10 ±45 ppm/°C
U W DY A IC ACCURACY The
C. VCC = 3V, fSAMPLE = 200kHz, tr = tf = 5ns, unless otherwise specified. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
S/(N + D) Signal-to-Noise 50kHz Input Signal ● 65 68 dB Plus Distortion Ratio 100kHz Input Signal 65 dB THD Total Harmonic Distortion 50kHz Input Signal ● – 72 – 65 dB Up to 5th Harmonic 100kHz Input Signal – 66 dB Peak Harmonic or 50kHz Input Signal ● – 74 – 65 dB Spurious Noise 100kHz Input Signal – 67 dB IMD Intermodulation Distortion fIN1 = 49.853kHz, fIN2 = 53.076kHz – 69 dB Full Power Bandwidth 2 MHz Full Linear Bandwidth (S/(N + D) ≥ 68dB) 50 kHz
U U DIGITAL I PUTS AND OUTPUTS The
VIH High Level Input Voltage VCC = 3.6V ● 2.0 V VIL Low Level Input Voltage VCC = 2.7V ● 0.8 V IIN Digital Input Current VIN = 0V to VCC ● ±10 µA CIN Digital Input Capacitance 5 pF VOH High Level Output Voltage VCC = 2.7V, IO = – 10µA ● 2.40 2.64 V VCC = 2.7V, IO = – 200µA ● 2.25 2.50 V VOL Low Level Output Voltage VCC = 2.7V, IO = 400µA ● 0.13 0.4 V IOZ Hi-Z Output Leakage DOUT VOUT = 0V to VCC ● ±10 µA COZ Hi-Z Output Capacitance DOUT 15 pF ISOURCE Output Source Current VOUT = 0V – 5 mA ISINK Output Sink Current VOUT = VCC 10 mA 1401fa 3
