Datasheet LTC1409 (Analog Devices) - 6
Описание12-Bit, 800ksps Sampling A/D Converter with Shutdown
Страниц / Страница20 / 6 — TYPICAL PERFORMANCE CHARACTERISTICS. Integral Nonlinearity vs. …
Формат / Размер файлаPDF / 356 Кб
TYPICAL PERFORMANCE CHARACTERISTICS. Integral Nonlinearity vs. Differential Nonlinearity vs. Output Code
TYPICAL PERFORMANCE CHARACTERISTICS Integral Nonlinearity vs Differential Nonlinearity vs Output Code
22 предложений от 19 поставщиков
Микросхема Преобразователь AD, IC ADC 12Bit 800KSPS SMPL 28SSOP
727GS
LTC1409IG
от 262 ₽
LTC1409IG
785 ₽
ТаймЧипс
LTC1409IG#TRPBF
LTC1409IG#TR
LTC1409
W U TYPICAL PERFORMANCE CHARACTERISTICS Integral Nonlinearity vs Differential Nonlinearity vs Output Code Output Code
1.00 1.00 0.50 0.50 0 0 INL ERROR (LSB) DNL ERROR (LSB) –0.50 –0.50 –1.00 –1.00 0 512 1024 1536 2048 2560 3072 3584 4096 0 512 1024 1536 2048 2560 3072 3584 4096 OUTPUT CODE OUTPUT CODE LT1409 • TPC07 LT1409 • TPC06
Power Supply Feedthrough vs Input Common Mode Rejection vs Ripple Frequency Input Frequency
0 80 –10 70 –20 60 –30 50 –40 –50 40 –60 30 –70 DGND 20 –80 VDD COMMON MODE REJECTION (dB) –90 VSS 10 –100 0 AMPLITUDE OF POWER SUPPLY FEEDTHROUGH (dB) 1k 10k 100k 1M 10M 1k 10k 100k 1M 10M RIPPLE FREQUENCY (Hz) INPUT FREQUENCY (Hz) LTC1409 • TPC08 LT1409 • TPC09
U U U PI FU CTIO S + A D3 to D0 (Pins 15 to 18):
Three-State Data Outputs.
IN (Pin 1):
Positive Analog Input, ±2.5V.
– A OGND (Pin 19):
Digital Ground for Output Drivers. Tie
IN (Pin 2):
Negative Analog Input, ±2.5V. to AGND.
VREF (Pin 3):
2.50V Reference Output.
NAP/SLP (Pin 20):
Power Shutdown Mode. Selects the
REFCOMP (Pin 4):
4.06V Reference Output. Bypass to mode invoked by the SHDN pin. Low selects Sleep AGND using 10µF tantalum in parallel with 0.1µF or mode and high selects quick wake-up Nap mode. 10µF ceramic.
SHDN (Pin 21):
Power Shutdown Input. A low logic
AGND (Pin 5):
Analog Ground. level will invoke the Shutdown mode selected by the
D11 to D4 (Pins 6 to 13):
Three-State Data Outputs. NAP/SLP pin.
DGND (Pin 14):
Digital Ground for Internal Logic. Tie to
RD (Pin 22):
Read Input. This enables the output AGND. drivers when CS is low. 6
