Datasheet LTC1414 (Analog Devices) - 6
Описание14-Bit, 2.2 Msps, Sampling A/D Converter
Страниц / Страница20 / 6 — PIN FUNCTIONS. BUSY (Pin 25):. AGND (Pin 27):. AVDD (Pin 28):. VSS (Pin …
Формат / Размер файлаPDF / 296 Кб
PIN FUNCTIONS. BUSY (Pin 25):. AGND (Pin 27):. AVDD (Pin 28):. VSS (Pin 26):. FUNCTIONAL BLOCK DIAGRA. W U. TI I G DIAGRA
PIN FUNCTIONS BUSY (Pin 25): AGND (Pin 27): AVDD (Pin 28): VSS (Pin 26): FUNCTIONAL BLOCK DIAGRA W U TI I G DIAGRA
14 предложений от 11 поставщиков
14 Bit Analog to Digital Converter 1 Input 1 SAR 28-SSOP
LTC1414IGN#TRPBF
810 ₽
LTC1414IGN#TRPBF
855 ₽
LTC1414IGN#TRPBF
1 771 ₽
Hi-Tech Circuit Group
LTC1414IGN#TRPBF
LTC1414
U U U PIN FUNCTIONS BUSY (Pin 25):
The BUSY Output Shows the Converter
AGND (Pin 27):
Analog Ground. Status. It is low when a conversion is in progress.
AVDD (Pin 28):
5V Positive Supply. Bypass to AGND with
VSS (Pin 26):
–5V Negative Supply. Bypass to AGND with 10µF ceramic or 10µF tantalum in parallel with 0.1µF 10µF ceramic or 10µF tantalum in parallel with 0.1µF ceramic. ceramic.
U U W FUNCTIONAL BLOCK DIAGRA
CSAMPLE A + IN AVDD CSAMPLE DVDD A – IN 2k V ZEROING SWITCHES SS VREF 2.5V REF + REF AMP 14-BIT CAPACITIVE DAC COMP – REFCOMP OVDD (4.06V) 14 SUCCESSIVE APPROXIMATION OUTPUT • D13 • REGISTER LATCHES • D0 AGND OGND INTERNAL CONTROL LOGIC DGND CLOCK 1414 BD CONVST BUSY
W U W TI I G DIAGRA
tCONV t4 t5 CONVST t1 t3 BUSY t2 DATA (N – 1) DATA N DATA (N + 1) DATA DB13 TO DB0 DB13 TO DB0 DB13 TO DB0 1414 TD 6
