Datasheet LTC1415 (Analog Devices) - 6
Описание12-Bit, 1.25Msps, 55mW Sampling A/D Converter
Страниц / Страница24 / 6 — TYPICAL PERFORMANCE CHARACTERISTICS. Power Supply Feedthrough vs. Input …
Формат / Размер файлаPDF / 338 Кб
TYPICAL PERFORMANCE CHARACTERISTICS. Power Supply Feedthrough vs. Input Common Mode Rejection. Ripple Frequency
TYPICAL PERFORMANCE CHARACTERISTICS Power Supply Feedthrough vs Input Common Mode Rejection Ripple Frequency
15 предложений от 12 поставщиков
IC ADC 12BIT SAR 28SOIC. 12 Bit Analog to Digital Converter 1 Input 1 SAR 28-SOIC. Data Acquisition - Analog to...
LTC1415ISW#TRPBF
767 ₽
LTC1415ISW#TRPBF
1 580 ₽
LTC1415ISW#TRPBF
SUV System
LTC1415ISW#TRPBF
LTC1415
W U TYPICAL PERFORMANCE CHARACTERISTICS Power Supply Feedthrough vs Input Common Mode Rejection Ripple Frequency vs Input Frequency
0 80 –10 70 –20 60 –30 –40 50 –50 40 –60 30 –70 VDD 20 –80 DGND COMMON MODE REJECTION (dB) –90 10 OVDD –100 0 AMPLITUDE OF POWER SUPPLY FEEDTHROUGH (dB) 1k 10k 100k 1M 2M 1k 10k 100k 1M 2M RIPPLE FREQUENCY (Hz) INPUT FREQUENCY (Hz) LTC1415 • TPC08 LTC1415 • TPC09
U U U PI FU CTIO S + A RD (Pin 22):
Read Input. This enables the output
IN (Pin 1):
Positive Analog Input, 0V to 4.096V. drivers when CS is low.
– AIN (Pin 2):
Negative Analog Input, 0V to 4.096V.
CONVST (Pin 23):
Conversion Start Signal. This active
VREF (Pin 3):
2.50V Reference Output. low signal starts a conversion on its falling edge.
REFCOMP (Pin 4):
Bypass to AGND with 10µF tantalum
CS (Pin 24):
The Chip Select input must be low for the in parallel with 0.1µF or 10µF ceramic. ADC to recognize CONVST and RD inputs.
AGND (Pin 5):
Analog Ground.
BUSY (Pin 25):
The BUSY output shows the converter
D11 to D4 (Pins 6 to 13):
Three-State Data Outputs. status. It is low when a conversion is in progress. Its
DGND (Pin 14):
Digital Ground. rising edge may be used to latch the output data.
D3 to D0 (Pins 15 to 18):
0VDD (Pin 26):
Digital output buffer supply. Short to Pin
OGND (Pin 19):
Digital Output Buffer Ground. 28 for 5V output. Tie to 3V for driving 3V logic.
NAP/SLP (Pin 20):
Power Shutdown Mode. High for
DVDD (Pin 27):
5V Positive Supply. Short to Pin 28. quick wake-up Nap mode.
AVDD (Pin 28):
5V Positive Supply. Bypass to AGND
SHDN (Pin 21):
Power Shutdown Input. A low logic with 10µF tantalum in parallel with 0.1µF or 10µF ceramic. level will invoke the Shutdown mode selected by the NAP/SLP pin. Tie high if unused. 6
