Datasheet LTC1594, LTC1598 (Analog Devices) - 3
Описание8-Channel, Micropower Sampling 12-Bit Serial I/O A/D Converter
Страниц / Страница24 / 3 — CONVERTER AND MULTIPLEXER CHARACTERISTICS The. denotes the specifications …
Формат / Размер файлаPDF / 246 Кб
CONVERTER AND MULTIPLEXER CHARACTERISTICS The. denotes the specifications which
CONVERTER AND MULTIPLEXER CHARACTERISTICS The denotes the specifications which
32 предложений от 22 поставщиков
Микросхема Преобразователь AD, LINEAR TECHNOLOGY LTC1598CG#PBF Analog to Digital Converter, 12Bit, 16.8KSPS, Single, 4.5V, 5.5V, SSOP
LTC1598CG#PBF
263 ₽
LTC1598CG#TRPBF
629 ₽
Элитан
LTC1598CG
1 900 ₽
LTC1598CG/IG
LTC1594/LTC1598
U U W CONVERTER AND MULTIPLEXER CHARACTERISTICS The
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25
C. (Note 5) LTC1594CS/LTC1598CG LTC1594IS/LTC1598IG PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
Resolution (No Missing Codes) ● 12 12 Bits Integral Linearity Error (Note 6) ● ±3 ±3 LSB Differential Linearity Error ● ± 3/4 ±1 LSB Offset Error ● ±3 ±3 LSB Gain Error ● ±8 ±8 LSB REF Input Range (Notes 7, 8) 1.5V to VCC + 0.05V V Analog Input Range (Notes 7, 8) – 0.05V to VCC + 0.05V V MUX Channel Input Leakage Current Off Channel ● ±200 ±200 nA MUXOUT Leakage Current Off Channel ● ±200 ±200 nA ADCIN Input Leakage Current (Note 9) ● ±1 ±1 μA
U W DYNAMIC ACCURACY (Note 5) fSMPL = 16.8kHz SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
S/(N + D) Signal-to-Noise Plus Distortion Ratio 1kHz Input Signal 71 dB THD Total Harmonic Distortion (Up to 5th Harmonic) 1kHz Input Signal – 78 dB SFDR Spurious-Free Dynamic Range 1kHz Input Signal 80 dB Peak Harmonic or Spurious Noise 1kHz Input Signal – 80 dB
U DIGITAL AND DC ELECTRICAL CHARACTERISTICS The
C. (Note 5) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VIH High Level Input Voltage VCC = 5.25V ● 2.6 V VIL Low Level Input Voltage VCC = 4.75V ● 0.8 V IIH High Level Input Current VIN = VCC ● 2.5 μA IIL Low Level Input Current VIN = 0V ● – 2.5 μA VOH High Level Output Voltage VCC = 4.75V, IO = – 10μA ● 4.0 4.64 V VCC = 4.75V, IO = –360A ● 2.4 4.62 V VOL Low Level Output Voltage VCC = 4.75V, IO = 1.6mA ● 0.4 V IOZ Hi-Z Output Leakage CS = High ● ±3 μA ISOURCE Output Source Current VOUT = 0V – 25 mA ISINK Output Sink Current VOUT = VCC 45 mA RREF Reference Input Resistance CS = VIH 5000 MΩ CS = VIL 55 kΩ IREF Reference Current CS = VCC ● 0.001 2.5 μA tCYC ≥ 760μs, fCLK ≤ 25kHz 90 μA tCYC ≥ 60μs, fCLK ≤ 320kHz ● 90 140 μA ICC Supply Current CS = VCC, CLK = VCC, DIN = VCC ● 0.001 ±7 μA tCYC ≥ 760μs, fCLK ≤ 25kHz 320 μA tCYC ≥ 60μs, fCLK ≤ 320kHz ● 320 690 μA 15948fb 3
