Datasheet LTC2152-12, LTC2151-12, LTC2150-12 (Analog Devices) - 4
ОписаниеSingle 12-Bit 250Msps ADCs
Страниц / Страница30 / 4 — INTERNAL. REFERENCE CHARACTERISTICS The. denotes the specifications which …
Формат / Размер файлаPDF / 689 Кб
INTERNAL. REFERENCE CHARACTERISTICS The. denotes the specifications which apply over the
INTERNAL REFERENCE CHARACTERISTICS The denotes the specifications which apply over the
IC ADC 12BIT PIPELINED 40QFN. 12 Bit Analog to Digital Converter 1 Input 1 Pipelined 40-QFN (6x6). Data Acquisition - Analog...
727GS
LTC2152IUJ-12#PBF
от 154 ₽
LTC2152IUJ-12#TRPBF
3 546 ₽
LTC2152IUJ-12#PBF
4 007 ₽
LTC2152IUJ-12#TRPBF
4 429 ₽
LTC2152-12/ LTC2151-12/LTC2150-12
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Note 5) PARAMETER CONDITIONS MIN TYP MAX UNITS
VCM Output Voltage IOUT = 0 0.439 • 0.439 • 0.439 • V VDD – 18mV VDD VDD + 18mV VCM Output Temperature Drift ±37 ppm/°C VCM Output Resistance –1mA < IOUT < 1mA 4 Ω VREF Output Voltage IOUT = 0 1.225 1.250 1.275 V VREF Output Temperature Drift ±30 ppm/°C VREF Output Resistance –400µA < IOUT < 1mA 7 Ω VREF Line Regulation 1.7V < VDD < 1.9V 0.6 mV/V
POWER REQUIREMENTS The
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Note 5) LTC2152-12 LTC2151-12 LTC2150-12 SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX MIN TYP MAX UNITS
VDD Analog Supply Voltage (Note 9) l 1.7 1.8 1.9 1.7 1.8 1.9 1.7 1.8 1.9 V OVDD Output Supply Voltage LVDS Mode (Note 9) l 1.7 1.8 1.9 1.7 1.8 1.9 1.7 1.8 1.9 V IVDD Analog Supply Current l 166 185 158 175 145 159 mA IOVDD Digital Supply Current 1.75mA LVDS Mode 27 32 27 31 25 30 mA 3.5mA LVDS Mode l 45 50 44 50 43 48 mA PDISS Power Dissipation 1.75mA LVDS Mode 347 391 333 371 306 340 mW 3.5mA LVDS Mode l 380 423 364 405 338 373 mW PNAP Nap Mode Power Clocked at fS(MAX) 105 99 93 mW PSLEEP Sleep Mode Power Clocked at fS(MAX) <2 <2 <2 mW
DIGITAL INPUTS AND OUTPUTS The
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Note 5) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS ENCODE INPUTS (ENC+, ENC– )
VID Differential Input Voltage (Note 8) l 0.2 1 1.9 V VICM Common Mode Input Voltage Internally Set 1.2 V Externally Set (Note 8) l 1.1 1.5 V VIN Input Voltage Range ENC+, ENC– to GND l 0.2 1.9 V RIN Input Resistance (See Figure 2) 10 kΩ CIN Input Capacitance (Note 8) 2 pF
DIGITAL INPUTS (CS, SDI, SCK)
VIH High Level Input Voltage VDD = 1.8V l 1.3 V VIL Low Level Input Voltage VDD = 1.8V l 0.6 V IIN Input Current VIN = 0V to 1.8V l –10 10 µA CIN Input Capacitance (Note 8) 3 pF
SDO OUTPUT (Open-Drain Output. Requires 2k Pull-Up Resistor if SDO Is Used)
ROL Logic Low Output Resistance to GND VDD = 1.8V, SDO = 0V 200 Ω IOH Logic High Output Leakage Current SDO = 0V to 3.6V l –10 10 µA COUT Output Capacitance (Note 8) 4 pF 21521012fa 4 For more information www.linear.com/LTC2152-12 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Converter Characteristics Analog Input Dynamic Accuracy Internal Reference Characteristics Power Requirements Digital Inputs And Outputs Timing Characteristics Typical Performance Characteristics Pin Functions Functional Block Diagram Timing Diagrams Applications Information Typical Applications Package Description Typical Application Related Parts
