Линейка продуктов KEEN SIDE
Datasheet LTC2165, LTC2164, LTC2163 (Analog Devices) - 4
Описание16-Bit, 125Msps Low Power ADCs
Страниц / Страница36 / 4 — converTer characTerisTics The. denotes the specifications which apply …
Формат / Размер файлаPDF / 684 Кб
converTer characTerisTics The. denotes the specifications which apply over the full operating
converTer characTerisTics The denotes the specifications which apply over the full operating
Микросхема Преобразователь AD, IC ADC 16Bit PAR/SRL 105M 48QFN
LTC2164CUK#TRPBF
2 414 ₽
LTC2164CUK#TRPBF
5 952 ₽
LifeElectronics
LTC2164CUK#TRPBF
LTC2164CUK#TRPBF
LTC2165/LTC2164/LTC2163
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. LTC2165 LTC2164 LTC2163 PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX MIN TYP MAX UNITS
Resolution (No Missing Codes) l 16 16 16 Bits Integral Linearity Error Differential Analog Input l –6 ±2 6 –6 ±2 6 –6 ±2 6 LSB (Note 6) Differential Linearity Error Differential Analog Input l –0.9 ±0.5 0.9 –0.9 ±0.5 0.9 –0.9 ±0.5 0.9 LSB Offset Error (Note 7) l –7 ±1.5 7 –7 ±1.5 7 –7 ±1.5 7 mV Gain Error Internal Reference ±1.5 ±1.5 ±1.5 %FS External Reference l –1.8 –0.5 0.7 –1.8 –0.5 0.7 –1.8 –0.5 0.7 %FS Offset Drift ±10 ±10 ±10 µV/°C Full-Scale Drift Internal Reference ±30 ±30 ±30 ppm/°C External Reference ±10 ±10 ±10 ppm/°C Transition Noise External Reference 3.4 3.5 3.2 LSBRMS
analog inpuT The
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Note 5) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
V + – IN Analog Input Range (AIN – AIN ) 1.7V < VDD < 1.9V l 1 to 2 VP-P V + – IN(CM) Analog Input Common Mode (AIN + AIN )/2 Differential Analog Input (Note 8) l 0.7 VCM 1.25 V VSENSE External Voltage Reference Applied to SENSE External Reference Mode l 0.625 1.250 1.300 V IINCM Analog Input Common Mode Current Per Pin, 125Msps 200 µA Per Pin, 105Msps 170 µA Per Pin, 80Msps 130 µA I + – IN1 Analog Input Leakage Current (No Encode) 0 < AIN , AIN < VDD l –1 1 µA IIN2 PAR/SER Input Leakage Current 0 < PAR/SER < VDD l –3 3 µA IIN3 SENSE Input Leakage Current 0.625 < SENSE < 1.3V l –6 6 µA tAP Sample-and-Hold Acquisition Delay Time 0 ns tJITTER Sample-and-Hold Acquisition Delay Jitter Single-Ended Encode 0.07 psRMS Differential Encode 0.09 psRMS CMRR Analog Input Common Mode Rejection Ratio 80 dB BW-3B Full Power Bandwidth Figure 6 Test Circuit 550 MHz
DynaMic accuracy The
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. AIN = –1dBFS. (Note 5) LTC2165 LTC2164 LTC2163 SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX MIN TYP MAX UNITS
SNR Signal-to-Noise Ratio 5MHz Input 76.8 76.7 77.1 dBFS 70MHz Input l 75 76.6 75 76.5 75.3 76.9 dBFS 140MHz Input 76.3 76 76.4 dBFS SFDR Spurious Free Dynamic Range 5MHz Input 90 90 90 dBFS 2nd Harmonic 70MHz Input l 80 89 80 89 82 89 dBFS 140MHz Input 84 84 84 dBFS SFDR Spurious Free Dynamic Range 5MHz Input 90 90 90 dBFS 3rd Harmonic 70MHz Input l 82 89 81 89 82 89 dBFS 140MHz Input 84 84 84 dBFS 216543f 4 Document Outline Features Applications Description Absolute Maximum Ratings Typical Application Pin Configuration Order Information Converter Characteristics Analog Input Dynamic Accuracy Internal Reference Characteristics Digital Inputs And Outputs Power Requirements Timing Characteristics Electrical Characteristics Timing Diagrams Typical Performance Characteristics Pin Functions Functional Block Diagram Applications Information Typical Applications Package Description Typical Application Related Parts
