Datasheet LTC2203, LTC2202 (Analog Devices) - 5
Описание16-Bit, 10Msps ADC
Страниц / Страница32 / 5 — DYNAMIC ACCURACY. The. denotes the specifi cations which apply over the …
DYNAMIC ACCURACY. The. denotes the specifi cations which apply over the full operating temperature range,
DYNAMIC ACCURACY The denotes the specifi cations which apply over the full operating temperature range,
LTC2203CUK#TRPBF
1 477 ₽
LTC2203CUK#TRPBF
2 286 ₽
LTC2203CUK#TRPBF
LTC2203CUK#TRPBF
LTC2203/LTC2202
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. AIN = –1dBFS. (Note 4) LTC2203 LTC2202 SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
SFDR Spurious Free 1MHz Input (2.5V Range, PGA = 0) 115 115 dBFS Dynamic Range 1MHz Input (1.667V Range, PGA = 1) 115 115 dBFS at –25dBFS 5MHz Input (2.5V Range, PGA = 0) l 100 115 100 115 dBFS Dither “ON” 5MHz Input (1.667V Range, PGA = 1) 115 115 dBFS 12.5MHz Input (2.5V Range, PGA = 0) 115 115 dBFS 12.5MHz Input (1.667V Range, PGA = 1) 115 115 dBFS 30MHz Input (2.5V Range, PGA = 0) 115 115 dBFS 30MHz Input (1.667V Range, PGA = 1) 115 115 dBFS 70MHz Input (2.5V Range, PGA = 0) 110 110 dBFS 70MHz Input (1.667V Range, PGA = 1) 110 110 dBFS
COMMON MODE BIAS CHARACTERISTICS The
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. (Note 4) PARAMETER CONDITIONS MIN TYP MAX UNITS
VCM Output Voltage IOUT = 0 1.15 1.25 1.35 V VCM Output Tempco IOUT = 0 ±40 ppm/°C VCM Line Regulation 3.135V ≤ VDD ≤ 3.465V 1 mV/ V VCM Output Resistance 1mA ≤ | IOUT | ≤ 1mA 2 Ω
DIGITAL INPUTS AND DIGITAL OUTPUTS The
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. (Note 4) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS LOGIC INPUTS (CLK, OE, DITH, PGA, SHDN, RAND)
VIH High Level Input Voltage VDD = 3.3V l 2 V VIL Low Level Input Voltage VDD = 3.3V l 0.8 V IIN Digital Input Current VIN = 0V to VDD l ±10 μA CIN Digital Input Capacitance (Note 7) 1.5 pF
LOGIC OUTPUTS OVDD = 3.3V
VOH High Level Output Voltage VDD = 3.3V IO = –10μA 3.299 V IO = –200μA l 3.1 3.29 V VOL Low Level Output Voltage VDD = 3.3V IO = 160μA 0.01 V IO = 1.6mA l 0.10 0.4 V ISOURCE Output Source Current VOUT = 0V –50 mA ISINK Output Sink Current VOUT = 3.3V 50 mA
OVDD = 2.5V
VOH High Level Output Voltage VDD = 3.3V IO = –200μA 2.49 V VOL Low Level Output Voltage VDD = 3.3V IO = 1.60mA 0.1 V
OVDD = 1.8V
VOH High Level Output Voltage VDD = 3.3V IO = –200μA 1.79 V VOL Low Level Output Voltage VDD = 3.3V IO = 1.60mA 0.1 V 22032fd 5
