Клеммники KEEN SIDE
Datasheet LTC2208 (Analog Devices) - 3
Описание16-Bit, 130Msps ADC
Страниц / Страница32 / 3 — The. ANALOG INPUT. denotes the specifi cations which apply over the full …
Формат / Размер файлаPDF / 987 Кб
The. ANALOG INPUT. denotes the specifi cations which apply over the full operating temperature range, otherwise
The ANALOG INPUT denotes the specifi cations which apply over the full operating temperature range, otherwise
29 предложений от 25 поставщиков
Микросхема Преобразователь AD, LINEAR TECHNOLOGY LTC2208CUP#PBF Analog to Digital Converter, 16Bit, 130MSPS, Single, 3.135V, 3.465V, QFN
LTC2208CUP
2 703 ₽
LTC2208CUP-14#TRPBF
4 120 ₽
SUV System
LTC2208CUP-14#TRPBF
TradeElectronics
LTC2208CUP#PBF
LTC2208
The ANALOG INPUT
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. (Note 4) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
V + – IN Analog Input Range (AIN – AIN ) 3.135V ≤ VDD ≤ 3.465V 1.5 or 2.25 VP-P VIN, CM Analog Input Common Mode Differential Input (Note 7) l 1 1.25 1.5 V I + – IN Analog Input Leakage Current 0V ≤ A l IN , AIN ≤ VDD –1 1 μA ISENSE SENSE Input Leakage Current 0V ≤ SENSE ≤ VDD l –3 3 μA IMODE MODE Pin Pull-Down Current to GND 10 μA ILVDS LVDS Pin Pull-Down Current to GND 10 μA CIN Analog Input Capacitance Sample Mode ENC+ < ENC– 6.5 pF Hold Mode ENC+ > ENC– 1.8 pF tAP Sample-and-Hold 1 ns Acquisition Delay Time tJITTER Sample-and-Hold 70 fs RMS Acquisition Delay Time Jitter CMRR Analog Input 1V < (A + – IN = AIN ) <1.5V 80 dB Common Mode Rejection Ratio BW-3dB Full Power Bandwidth RS < 25Ω 700 MHz
The DYNAMIC ACCURACY
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. AIN = –1dBFS. (Note 4) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
SNR Signal-to-Noise Ratio 5MHz Input (2.25V Range, PGA = 0) 77.7 dBFS 5MHz Input (1.5V Range, PGA = 1) 75.3 dBFS 30MHz Input (2.25V Range, PGA = 0) TA = 25°C 76.5 77.6 dBFS 30MHz Input (2.25V Range, PGA = 0) l 76.1 77.3 dBFS 30MHz Input (1.5V Range, PGA = 1) 75.2 dBFS 70MHz Input (2.25V Range, PGA = 0) 77.5 dBFS 70MHz Input (1.5V Range, PGA = 1) 75.1 dBFS 140MHz Input (2.25V Range, PGA = 0) 76.9 dBFS 140MHz Input (1.5V Range, PGA = 1) TA = 25°C 73.8 74.8 dBFS 140MHz Input (1.5V Range, PGA = 1) l 73.4 74.5 dBFS 250MHz Input (2.25V Range, PGA = 0) 75.4 dBFS 250MHz Input (1.5V Range, PGA =1) 73.8 dBFS SFDR Spurious Free 5MHz Input (2.25V Range, PGA = 0) 100 dBc Dynamic Range 5MHz Input (1.5V Range, PGA = 1) 100 dBc 2nd or 3rd Harmonic 30MHz Input (2.25V Range, PGA = 0) TA = 25°C 88 95 dBc 30MHz Input (2.25V Range, PGA = 0) l 87 94 dBc 30MHz Input (1.5V Range, PGA = 1) 100 dBc 70MHz Input (2.25V Range, PGA = 0) 90 dBc 70MHz Input (1.5V Range, PGA = 1) 95 dBc 140MHz Input (2.25V Range, PGA = 0) 85 dBc 140MHz Input (1.5V Range, PGA = 1) TA = 25°C 86 90 dBc 140MHz Input (1.5V Range, PGA = 1) l 84 89 dBc 250MHz Input (2.25V Range, PGA = 0) 78 dBc 250MHz Input (1.5V Range, PGA = 1) 83 dBc 2208fc 3
