Datasheet LTC2222, LTC2223 (Analog Devices) - 3
Описание12-Bit, 80Msps ADCs
Страниц / Страница28 / 3 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
Формат / Размер файлаPDF / 946 Кб
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the full operating
16 предложений от 15 поставщиков
Микросхема Преобразователь AD, IC ADC 12Bit 80MSPS SAMPLE 48QFN
LTC2223CUK
1 502 ₽
LTC2223CUK
2 021 ₽
LTC2223CUK#TRPBF
Hi-Tech Circuit Group
LTC2223CUK#PBF
LTC2222/LTC2223
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. LTC2222 LTC2223 PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
Resolution (No Missing Codes) l 12 12 Bits Integral Linearity Error (Note 5) Differential Analog Input l –1.3 ±0.3 1.3 –1.1 ±0.3 1.1 LSB Differential Linearity Error Differential Analog Input l –1 ±0.2 1 –0.8 ±0.2 0.8 LSB Integral Linearity Error (Note 5) Single-Ended Analog Input ±1 ±1 LSB Differential Linearity Error Single-Ended Analog Input ±0.2 ±0.2 LSB Offset Error (Note 6) l –30 ±3 30 –30 ±3 30 mV Gain Error External Reference l –2.5 ±0.5 2.5 –2.5 ±0.5 2.5 %FS Offset Drift ±10 ±10 μV/C Full-Scale Drift Internal Reference ±30 ±30 ppm/C External Reference ±15 ±15 ppm/C Transition Noise SENSE = 1V 0.5 0.5 LSBRMS
ANALOG INPUT The
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. (Note 4) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
V + – IN Analog Input Range (AIN – AIN ) 3.1V < VDD < 3.5V l ±0.5 to ±1 V V + – IN, CM Analog Input Common Mode (AIN + AIN )/2 Differential Input l 1 1.6 1.9 V Single-Ended Input (Note 7) l 0.5 1.6 2.1 V I + – IN Analog Input Leakage Current 0 < AIN , AIN < VDD l –1 1 μA ISENSE SENSE Input Leakage 0V < SENSE < 1V l –1 1 μA IMODE MODE Pin Pull-Down Current to GND 10 μA Full Power Bandwidth Figure 8 Test Circuit 775 MHz tAP Sample and Hold Acquisition Delay Time 0 ns tJITTER Sample and Hold Acquisition Delay Time Jitter 0.15 psRMS CMRR Analog Input Common Mode Rejection Ratio 80 dB 22223fb 3
