Datasheet LTC2222, LTC2223 (Analog Devices) - 6
Описание12-Bit, 80Msps ADCs
Страниц / Страница28 / 6 — TIMING CHARACTERISTICS. The. denotes the specifi cations which apply over …
Формат / Размер файлаPDF / 946 Кб
TIMING CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating temperature
TIMING CHARACTERISTICS The denotes the specifi cations which apply over the full operating temperature
26 предложений от 22 поставщиков
Микросхема Преобразователь AD, LINEAR TECHNOLOGY LTC2222CUK#PBF Analog to Digital Converter, 12Bit, 105MSPS, Single, 3.1V, 3.5V, QFN
Элитан
LTC2222CUK
8 443 ₽
LTC2222CUK-11#PBF
ТаймЧипс
LTC2222CUK#TR
LTC2222CUK#PBF
LTC2222/LTC2223
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. (Note 4) LTC2222 LTC2223 SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
fS Sampling Frequency l 1 105 1 80 MHz tL ENC Low Time Duty Cycle Stabilizer Off l 4.5 4.76 500 5.9 6.25 500 ns Duty Cycle Stabilizer On l 3 4.76 500 3 6.25 500 ns tH ENC High Time Duty Cycle Stabilizer Off l 4.5 4.76 500 5.9 6.25 500 ns Duty Cycle Stabilizer On l 3 4.76 500 3 6.25 500 ns tAP Sample-and-Hold Aperture Delay 0 0 ns tD ENC to DATA Delay (Note 7) l 1.3 2.1 4 1.3 2.1 4 ns tC ENC to CLOCKOUT Delay (Note 7) l 1.3 2.1 4 1.3 2.1 4 ns DATA to CLOCKOUT Skew (tC - tD) (Note 7) l –0.6 0 0.6 –0.6 0 0.6 ns tOE Output Enable Delay (Note 7) l 5 10 5 10 ns Pipeline Latency 5 5 Cycles
Note 1:
Note 5:
Integral nonlinearity is defi ned as the deviation of a code from a may cause permanent damage to the device. Exposure to any Absolute straight line passing through the actual endpoints of the transfer curve. Maximum Rating condition for extended periods may affect device The deviation is measured from the center of the quantization band. reliability and lifetime.
Note 6:
Offset error is the offset voltage measured from –0.5 LSB when
Note 2:
All voltage values are with respect to ground with GND and OGND the output code fl ickers between 0000 0000 0000 and 1111 1111 1111 in wired together (unless otherwise noted). 2’s complement output mode.
Note 3:
When these pin voltages are taken below GND or above VDD, they
Note 7:
Guaranteed by design, not subject to test. will be clamped by internal diodes. This product can handle input currents
Note 8:
VDD = 3.3V, fSAMPLE = 105MHz (LTC2222) or 80MHz (LTC2223), of greater than 100mA below GND or above VDD without latchup. differential ENC+/ENC– = 2VP-P sine wave, input range = 1VP-P with
Note 4:
VDD = 3.3V, fSAMPLE = 105MHz (LTC2222) or 80MHz (LTC2223), differential drive. differential ENC+/ENC– = 2VP-P sine wave, input range = 2VP-P with differential drive, unless otherwise noted. 22223fb 6
