Datasheet LTC2226H (Analog Devices) - 4
Описание12-Bit, 25Msps 125°C ADC in LQFP
Страниц / Страница18 / 4 — DIGITAL INPUTS AND DIGITAL OUTPUTS. The. denotes the specifications which …
Формат / Размер файлаPDF / 259 Кб
DIGITAL INPUTS AND DIGITAL OUTPUTS. The. denotes the specifications which apply over the full
DIGITAL INPUTS AND DIGITAL OUTPUTS The denotes the specifications which apply over the full
35 предложений от 20 поставщиков
Микросхема Преобразователь AD, LTC2226H - 12Bit, 25MSPS 125℃ ADC in LQFP
727GS
LTC2226HLX#PBF
от 306 ₽
ЧипСити
LTC2226HLX#PBF
1 095 ₽
Элитан
LTC2226HLX
3 140 ₽
TradeElectronics
LTC2226HLX-PBF
LTC2226H
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Note 4) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS LOGIC OUTPUTS OVDD = 3V
COZ Hi-Z Output Capacitance OE = High (Note 7) 3 pF ISOURCE Output Source Current VOUT = 0V 50 mA ISINK Output Sink Current VOUT = 3V 50 mA VOH High Level Output Voltage IO = –10µA 2.995 V IO = –200µA l 2.7 2.99 V VOL Low Level Output Voltage IO = 10µA 0.005 V IO = 1.6mA l 0.09 0.4 V
OVDD = 2.5V
VOH High Level Output Voltage IO = –200µA 2.49 V VOL Low Level Output Voltage IO = 1.6mA 0.09 V
OVDD = 1.8V
VOH High Level Output Voltage IO = –200µA 1.79 V VOL Low Level Output Voltage IO = 1.6mA 0.09 V
POWER REQUIREMENTS The
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Note 8) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VDD Analog Supply Voltage (Note 9) l 2.8 3 3.5 V OVDD Output Supply Voltage (Note 9) l 0.5 3 3.6 V IVDD Supply Current l 25 30 mA PDISS Power Dissipation l 75 90 mW PSHDN Shutdown Power SHDN = H, OE = H, No CLK 2 mW PNAP Nap Mode Power SHDN = H, OE = L, No CLK 15 mW
TIMING CHARACTERISTICS The
l
fS Sampling Frequency (Note 9) l 1 25 MHz tL CLK Low Time Duty Cycle Stabilizer Off l 18.9 20 500 ns Duty Cycle Stabilizer On l 5 20 500 ns (Note 7) tH CLK High Time Duty Cycle Stabilizer Off l 18.9 20 500 ns Duty Cycle Stabilizer On l 5 20 500 ns (Note 7) tAP Sample-and-Hold Aperture Delay 0 ns tD CLK to DATA Delay CL = 5pF (Note 7) l 1.4 2.7 6 ns Data Access Time After OE↓ CL = 5pF (Note 7) l 4.3 12 ns BUS Relinquish Time (Note 7) l 3.3 10 ns Pipeline Latency 5 Cycles 2226hfc 4
