Datasheet LTC2240-10 (Analog Devices) - 3
Описание10-Bit, 170Msps ADC
Страниц / Страница28 / 3 — CONVERTER CHARACTERISTICS The. denotes the specifi cations which apply …
Формат / Размер файлаPDF / 480 Кб
CONVERTER CHARACTERISTICS The. denotes the specifi cations which apply over the full operating
CONVERTER CHARACTERISTICS The denotes the specifi cations which apply over the full operating
23 предложений от 20 поставщиков
IC ADC 10BIT PIPELINED 64QFN. 10 Bit Analog to Digital Converter 1 Input 1 Pipelined 64-QFN (9x9). Data Acquisition - Analog...
LTC2240IUP-10#TRPBF
2 936 ₽
LTC2240IUP-10#PBF
4 145 ₽
LTC2240IUP-10#PBF
8 348 ₽
ТаймЧипс
LTC2240IUP-10
LTC2240-10
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. (Note 4) PARAMETER CONDITIONS MIN TYP MAX UNITS
Resolution (No Missing Codes) l 10 Bits Integral Linearity Error Differential Analog Input (Note 5) l –0.8 ±0.3 0.8 LSB Differential Linearity Error Differential Analog Input l –0.6 ±0.1 0.6 LSB Offset Error (Note 6) l –15 ±5 15 mV Gain Error External Reference l –3.8 ±0.7 3.8 %FS Offset Drift ±10 μV/C Full-Scale Drift Internal Reference ±60 ppm/C External Reference ±45 ppm/C Transition Noise SENSE = 1V 0.18 LSBRMS
ANALOG INPUT The
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. (Note 4) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
V + – IN Analog Input Range (AIN – AIN ) 2.375V < VDD < 2.625V (Note 7) l ±0.5 to ±1 V V + – IN, CM Analog Input Common Mode (AIN + AIN )/2 Differential Input (Note 7) l 1.2 1.25 1.3 V I + – IN Analog Input Leakage Current 0 < AIN , AIN < VDD l –1 1 μA ISENSE SENSE Input Leakage 0V < SENSE < 1V l –1 1 μA IMODE MODE Pin Pull-Down Current to GND 7 μA ILVDS LVDS Pin Pull-Down Current to GND 7 μA tAP Sample and Hold Acquisition Delay Time 0.4 ns tJITTER Sample and Hold Acquisition Delay Time Jitter 95 fsRMS Full Power Bandwidth Figure 8 Test Circuit 1200 MHz
DYNAMIC ACCURACY The
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. AIN = –1dBFS. (Note 4) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
SNR Signal-to-Noise Ratio (Note 10) 10MHz Input 60.6 dB 70MHz Input l 59.7 60.6 dB 140MHz Input 60.5 dB 240MHz Input 60.5 dB SFDR Spurious Free Dynamic Range 10MHz Input 80 dB 2nd or 3rd Harmonic 70MHz Input l 65 75 dB (Note 11) 140MHz Input 74 dB 240MHz Input 72 dB Spurious Free Dynamic Range 10MHz Input 85 dB 4th Harmonic or Higher 70MHz Input l 74 85 dB (Note 11) 140MHz Input 85 dB 240MHz Input 85 dB 224010fb 3
