Datasheet LTC2246H (Analog Devices) - 4
Описание14-Bit, 25Msps 125°C ADC In LQFP
Страниц / Страница18 / 4 — DIGITAL INPUTS AND DIGITAL OUTPUTS. The. denotes the specifi cations which …
Формат / Размер файлаPDF / 205 Кб
DIGITAL INPUTS AND DIGITAL OUTPUTS. The. denotes the specifi cations which apply over the full
DIGITAL INPUTS AND DIGITAL OUTPUTS The denotes the specifi cations which apply over the full
27 предложений от 18 поставщиков
ADC, Proprietary Method, 14-Bit, 1 Func, 1 Channel, Parallel, Word Access, CMOS, PQFP48
727GS
LTC2246HLX#PBF
от 185 ₽
LTC2246HLX#PBF
885 ₽
Эиком
LTC2246HLX#PBF
от 5 594 ₽
LTC2246HLX PBF
LTC2246H
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. (Note 4) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS LOGIC OUTPUTS OVDD = 3V
COZ Hi-Z Output Capacitance OE = High (Note 7) 3 pF ISOURCE Output Source Current VOUT = 0V 50 mA ISINK Output Sink Current VOUT = 3V 50 mA VOH High Level Output Voltage IO = –10μA 2.995 V IO = –200μA l 2.7 2.99 V VOL Low Level Output Voltage IO = 10μA 0.005 V IO = 1.6mA l 0.09 0.4 V
OVDD = 2.5V
VOH High Level Output Voltage IO = –200μA 2.49 V VOL Low Level Output Voltage IO = 1.6mA 0.09 V
OVDD = 1.8V
VOH High Level Output Voltage IO = –200μA 1.79 V VOL Low Level Output Voltage IO = 1.6mA 0.09 V
POWER REQUIREMENTS The
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. (Note 8) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VDD Analog Supply Voltage (Note 9) l 2.8 3 3.5 V OVDD Output Supply Voltage (Note 9) l 0.5 3 3.6 V IVDD Supply Current l 25 30 mA PDISS Power Dissipation l 75 90 mW PSHDN Shutdown Power SHDN = H, OE = H, No CLK 2 mW PNAP Nap Mode Power SHDN = H, OE = L, No CLK 15 mW
TIMING CHARACTERISTICS The
l
fS Sampling Frequency (Note 9) l 1 25 MHz tL CLK Low Time Duty Cycle Stabilizer Off l 18.9 20 500 ns Duty Cycle Stabilizer On l 5 20 500 ns (Note 7) tH CLK High Time Duty Cycle Stabilizer Off l 18.9 20 500 ns Duty Cycle Stabilizer On l 5 20 500 ns (Note 7) tAP Sample-and-Hold Aperture Delay 0 ns tD CLK to DATA Delay CL = 5pF (Note 7) l 1.4 2.7 6 ns Data Access Time After OE↓ CL = 5pF (Note 7) l 4.3 12 ns BUS Relinquish Time (Note 7) l 3.3 10 ns Pipeline Latency 5 Cycles 2246hfb 4
