Datasheet LTC2262-12 (Analog Devices) - 5
Описание12-Bit, 150Msps Ultralow Power 1.8V ADC
Страниц / Страница28 / 5 — DIGITAL INPUTS AND OUTPUTS. The. denotes the specifications which apply …
Формат / Размер файлаPDF / 546 Кб
DIGITAL INPUTS AND OUTPUTS. The. denotes the specifications which apply over the full operating
DIGITAL INPUTS AND OUTPUTS The denotes the specifications which apply over the full operating
, 1-Channel Single ADC Pipelined 150Msps 12-bit Parallel/LVDS 40-Pin QFN EP T/R
LTC2262CUJ-12#TRPBF
2 752 ₽
LTC2262CUJ-12#TRPBF
3 436 ₽
LTC2262CUJ-12#TRPBF
LifeElectronics
LTC2262CUJ-12#TRPBF
LTC2262-12
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Note 5) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS DIGITAL INPUTS (CS, SDI, SCK)
VIH High Level Input Voltage VDD = 1.8V l 1.3 V VIL Low Level Input Voltage VDD = 1.8V l 0.6 V IIN Input Current VIN = 0V to 3.6V l –10 10 µA CIN Input Capacitance (Note 8) 3 pF
SDO OUTPUT (Open-Drain Output. Requires 2k Pull-Up Resistor if SDO is Used)
ROL Logic Low Output Resistance to GND VDD = 1.8V, SDO = 0V 200 Ω IOH Logic High Output Leakage Current SDO = 0V to 3.6V l –10 10 µA COUT Output Capacitance (Note 8) 4 pF
DIGITAL DATA OUTPUTS (CMOS MODES: FULL DATA RATE AND DOUBLE DATA RATE) OVDD = 1.8V
VOH High Level Output Voltage IO = –500µA l 1.750 1.790 V VOL Low Level Output Voltage IO = 500µA l 0.010 0.050 V
OVDD = 1.5V
VOH High Level Output Voltage IO = –500µA 1.488 V VOL Low Level Output Voltage IO = 500µA 0.010 V
OVDD = 1.2V
VOH High Level Output Voltage IO = –500µA 1.185 V VOL Low Level Output Voltage IO = 500µA 0.010 V
DIGITAL DATA OUTPUTS (LVDS MODE)
VOD Differential Output Voltage 100Ω Differential Load, 3.5mA Mode l 247 350 454 mV 100Ω Differential Load, 1.75mA Mode 175 mV VOS Common Mode Output Voltage 100Ω Differential Load, 3.5mA Mode l 1.125 1.250 1.375 V 100Ω Differential Load, 1.75mA Mode 1.250 V RTERM On-Chip Termination Resistance Termination Enabled, OVDD = 1.8V 100 Ω
POWER REQUIREMENTS The
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Note 9) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS CMOS Output Modes: Full Data Rate and Double Data Rate
VDD Analog Supply Voltage (Note 10) l 1.7 1.8 1.9 V OVDD Output Supply Voltage (Note 10) l 1.1 1.9 V IVDD Analog Supply Current DC Input l 80.9 93 mA Sine Wave Input 82.7 mA IOVDD Digital Supply Current Sine Wave Input, OVDD=1.2V 5.1 mA PDISS Power Dissipation DC Input l 146 168 mW Sine Wave Input, OVDD=1.2V 155 mW 226212fc For more information www.linear.com/LTC2262-12 5 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Typical Performance Characteristics Pin Functions Block Diagram Applications Information Related Parts
