Datasheet LTC2274 (Analog Devices) - 4
Описание16-Bit, 105Msps Serial Output ADC (JESD204)
Страниц / Страница40 / 4 — The. DYNAMIC ACCURACY. denotes the specifi cations which apply over the …
Формат / Размер файлаPDF / 924 Кб
The. DYNAMIC ACCURACY. denotes the specifi cations which apply over the full operating temperature range,
The DYNAMIC ACCURACY denotes the specifi cations which apply over the full operating temperature range,
12 предложений от 11 поставщиков
, 16-Bit, 105Msps Serial Output ADC (JESD204)
727GS
LTC2274IUJ#TRPBF
от 164 ₽
LTC2274IUJ#TRPBF
Hi-Tech Circuit Group
LTC2274IUJ#TRPBF
LTC2274IUJ#TRPBF
LTC2274
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. AIN = –1dBFS unless otherwise noted. (Note 4) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
SFDR Spurious Free Dynamic Range 4th 5MHz Input (2.25V Range, PGA = 0) 100 dBc Harmonic or Higher 5MHz Input (1.5V Range, PGA = 1) 100 dBc 15MHz Input (2.25V Range, PGA = 0) l 90 100 dBc 15MHz Input (1.5V Range, PGA = 1) 100 dBc 70MHz Input (2.25V Range, PGA = 0) 100 dBc 70MHz Input (1.5V Range, PGA = 1) 100 dBc 140MHz Input (2.25V Range, PGA = 0) 95 dBc 140MHz Input (1.5V Range, PGA = 1) l 85 100 dBc 170MHz Input (2.25V Range, PGA = 0) 90 dBc 170MHz Input (1.5V Range, PGA = 1) 95 dBc S/(N+D) Signal-to-Noise 5MHz Input (2.25V Range, PGA = 0) 77.5 dBFS Plus Distortion Ratio 5MHz Input (1.5V Range, PGA = 1) 75.3 dBFS 15MHz Input (2.25V Range, PGA = 0), TA = 25°C 76.3 77.4 dBFS 15MHz Input (2.25V Range, PGA = 0 l 75.9 77 dBFS 15MHz Input (1.5V Range, PGA = 1) 75.2 dBFS 70MHz Input (2.25V Range, PGA = 0) 76.7 dBFS 70MHz Input (1.5V Range, PGA = 1) 74.2 dBFS 140MHz Input (2.25V Range, PGA = 0), TA = 25°C 75.3 dBFS 140MHz Input (1.5V Range, PGA = 1) 73.6 74.3 dBFS 140MHz Input (1.5V Range, PGA = 1) l 73.2 74 dBFS 170MHz Input (2.25V Range, PGA = 0) 73.4 dBFS 170MHz Input (1.5V Range, PGA = 1) 73.4 dBFS SFDR Spurious Free Dynamic Range 5MHz Input (2.25V Range, PGA = 0) 105 dBFS at –25dBFS Dither “OFF” 5MHz Input (1.5V Range, PGA = 1) 105 dBFS 15MHz Input (2.25V Range, PGA = 0) 105 dBFS 15MHz Input (1.5V Range, PGA = 1) 105 dBFS 70MHz Input (2.25V Range, PGA = 0) 105 dBFS 70MHz Input (1.5V Range, PGA = 1) 105 dBFS 140MHz Input (2.25V Range, PGA = 0) 100 dBFS 140MHz Input (1.5V Range, PGA = 1) 100 dBFS 170MHz Input (2.25V Range, PGA = 0) 100 dBFS 170MHz Input (1.5V Range, PGA = 1) 100 dBFS SFDR Spurious Free Dynamic Range 5MHz Input (2.25V Range, PGA = 0) 115 dBFS at –25dBFS Dither “ON” 5MHz Input (1.5V Range, PGA = 1) 115 dBFS 15MHz Input (2.25V Range, PGA = 0) l 97 115 dBFS 15MHz Input (1.5V Range, PGA = 1) 115 dBFS 70MHz Input (2.25V Range, PGA = 0) 115 dBFS 70MHz Input (1.5V Range, PGA = 1) 115 dBFS 140MHz Input (2.25V Range, PGA = 0) 110 dBFS 140MHz Input (1.5V Range, PGA = 1) 110 dBFS 170MHz Input (2.25V Range, PGA = 0) 105 dBFS 170MHz Input (1.5V Range, PGA = 1) 105 dBFS 2274fb 4
