Datasheet LTC2301, LTC2305 (Analog Devices) - 3
Описание2-Channel, 12-Bit ADCs with I2C Compatible Interface
Страниц / Страница26 / 3 — ORDER INFORMATION. LEAD FREE FINISH. TAPE AND REEL. PART MARKING. PACKAGE …
Формат / Размер файлаPDF / 907 Кб
ORDER INFORMATION. LEAD FREE FINISH. TAPE AND REEL. PART MARKING. PACKAGE DESCRIPTION. TEMPERATURE RANGE
ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING PACKAGE DESCRIPTION TEMPERATURE RANGE
IC ADC 12BIT SAR 12DFN. 12 Bit Analog to Digital Converter 1 Input 1 SAR 12-DFN (4x3). Data Acquisition - Analog...
LTC2301CDE#TRPBF
100 ₽
LTC2301CDE#TRPBF
160 ₽
Рутоника
LTC2301CDE#TRPBF
202 ₽
LTC2301CDE#TRPBF
LTC2301/LTC2305
LTC2305IMS#PBF LTC2305IMS#TRPBF 2305 12-Lead Plastic MSOP –40°C to 85°C LTC2305HMS#PBF LTC2305HMS#TRPBF 2305 12-Lead Plastic MSOP –40°C to 125°C Consult LTC Marketing for parts specifi ed with wider operating temperature ranges. *The temperature grade is identifi ed by a label on the shipping container. Consult LTC Marketing for information on non-standard lead based fi nish parts. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifi cations, go to: http://www.linear.com/tapeandreel/
CONVERTER AND MULTIPLEXER CHARACTERISTICS The
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. (Note 4) PARAMETER CONDITIONS MIN TYP MAX UNITS
Resolution (No Missing Codes) l 12 Bits Integral Linearity Error (Note 5) l ±0.4 ±1 LSB Differential Linearity Error l ±0.3 ±1 LSB Bipolar Zero Error (Note 6) l ±0.5 ±8 LSB Bipolar Zero Error Drift 0.002 LSB/°C Unipolar Zero Error (Note 6) l ±0.7 ±6 LSB Unipolar Zero Error Drift 0.002 LSB/°C Unipolar Zero Error Match (LTC2305) ±0.1 ±1 LSB Bipolar Full-Scale Error External Reference (Note 7) l ±1 ±10 LSB REFCOMP = 4.096V (Note 7) l ±0.9 ±9 LSB Bipolar Full-Scale Error Drift External Reference 0.05 LSB/°C Unipolar Full-Scale Error External Reference (Note 7) l ±0.5 ±10 LSB REFCOMP = 4.096V (Note 7) l ±0.7 ±6 LSB Unipolar Full-Scale Error Drift External Reference 0.05 LSB/°C Unipolar Full-Scale Error Match (LTC2305) ±0.1 ±2 LSB
ANALOG INPUT The
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. (Note 4) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VIN+ Absolute Input Range (CH0, CH1, IN+) (Note 8) l –0.05 REFCOMP V VIN– Absolute Input Range (CH0, CH1, IN–) Unipolar (Note 8) l –0.05 0.25 • REFCOMP V Bipolar (Note 8) –0.05 0.75 • REFCOMP V VIN+ – VIN– Input Differential Voltage Range VIN = VIN+ – VIN– (Unipolar) l 0 to REFCOMP V VIN = VIN+ – VIN– (Bipolar) ±REFCOMP/2 V IIN Analog Input Leakage Current l ±1 μA CIN Analog Input Capacitance Sample Mode 55 pF Hold Mode 5 pF CMRR Input Common Mode Rejection Ratio 70 dB 23015fb 3
