Datasheet LTC2309 (Analog Devices) - 4
Описание8-Channel, 12-Bit SAR ADC with I2C Interface
Страниц / Страница26 / 4 — The. denotes the specifications which apply over the full
The denotes the specifications which apply over the full
38 предложений от 20 поставщиков
Микросхема Преобразователь AD, LINEAR TECHNOLOGY LTC2309CUF#PBF Analog to Digital Converter, 12Bit, 14KSPS, Single, 4.75V, 5.25V, QFN
LTC2309CUF#PBF
от 141 ₽
LTC2309CUF/IUF
234 ₽
Microfind
LTC2309CUF#PBF
837 ₽
ТаймЧипс
LTC2309CUF-TRPBF
LTC2309 I nteRnAL ReFeRenCe CHARACteRIstICs
The
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Note 4) PARAMETER CONDITIONS MIN TYP MAX UNITS
VREF Output Voltage IOUT = 0 (QFN) l 2.47 2.50 2.53 V IOUT = 0 (TSSOP) l 2.46 2.50 2.54 V VREF Output Tempco IOUT = 0 ±25 ppm/°C VREF Output Impedance –0.1mA ≤ IOUT ≤ 0.1mA 8 kΩ VREFCOMP Output Voltage IOUT = 0 4.096 V VREF Line Regulation VDD = 4.75V to 5.25V 0.8 mV/V I2 C Inputs AnD DIGItAL Outputs
The
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Note 4) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VIH High Level Input Voltage l 2.85 V VIL Low Level Input Voltage l 1.5 V VIHA High Level Input Voltage for Address Pins A1, A0 l 4.75 V VILA Low Level Input Voltage for Address Pins A1, A0 l 0.25 V RINH Resistance from A1, A0, to VDD to Set Chip l 10 kΩ Address Bit to 1 RINL Resistance from A1, A0 to GND to Set Chip l 10 kΩ Address Bit to 0 RINF Resistance from A1, A0 to GND or VDD to Set l 2 MΩ Chip Address Bit to Float II Digital Input Current VIN = VDD l –10 10 µA VHYS Hysteresis of Schmitt Trigger Inputs (Note 9) l 0.25 V VOL Low Level Output Voltage (SDA) I = 3mA l 0.4 V tOF Output Fall Time VH to VIL(MAX) (Note 12) l 20 + 0.1CB 250 ns tSP Input Spike Suppression l 50 ns CCAX External Capacitance Load On-Chip Address Pins l 10 pF (A1, A0) for Valid Float p OWeR ReQuIReMents
The
l
VDD Supply Voltage l 4.75 5 5.25 V IDD Supply Current 14ksps Sample Rate l 2.3 3 mA Nap Mode SLP Bit = 0, Conversion Done l 210 350 µA Sleep Mode SLP Bit = 1, Conversion Done l 7 15 µA PD Power Dissipation 14ksps Sample Rate l 11.5 15 mW Nap Mode SLP Bit = 0, Conversion Done l 1.05 1.75 mW Sleep Mode SLP Bit = 1, Conversion Done l 35 75 µW 2309fd Document Outline Features Description Applications Absolute Maximum Ratings Pin Configuration Order Information CONVERTER AND MULTIPLEXER CHARACTERISTICS ANALOG INPUT DYNAMIC ACCURACY INTERNAL REFERENCE CHARACTERISTICS I2C Inputs and Digital Outputs POWER REQUIREMENTS I2C TIMING CHARACTERISTICS ADC TIMING CHARACTERISTICS Typical Performance Characteristics Pin Functions Functional Block Diagram TIMING DIAGRAM Applications Information Package Description Revision History Typical Application Related Parts
