Datasheet LTC2311-14 (Analog Devices) - 2
Описание14-Bit + Sign, 5Msps Differential Input ADC with Wide Input Common Mode Range
Страниц / Страница26 / 2 — ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Notes 1, 2)
Формат / Размер файлаPDF / 895 Кб
ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION (Notes 1, 2)
21 предложений от 13 поставщиков
IC ADC 14BIT SAR 16MSOP. 14 Bit Analog to Digital Converter 1 Input 1 SAR 16-MSOP-EP. Data Acquisition - Analog to...
LTC2311HMSE-14#PBF
599 ₽
Рутоника
LTC2311HMSE-14#TRPBF
1 191 ₽
LTC2311HMSE-14#PBF
1 864 ₽
Элитан
LTC2311HMSE-14#WPBF
3 321 ₽
LTC2311-14
Supply Voltage (VDD) ..6V Supply Voltage (OVDD) ..3V Analog Input Voltage A TOP VIEW IN+, AIN– (Note 3) ... –0.3V to (VDD + 0.3V) REFIN, REFOUT ... –0.3V to (V GND 1 16 SCK+ DD + 0.3V) REFIN 2 15 SCK– CNV (Note 15) .. –0.3V to (V REFOUT 3 14 SDO+ DD + 0.3V) V 4 17 DD 13 SDO– Digital Input Voltage GND 5 GND 12 OVDD A 6 IN+ 11 GND (Note 3) .. (GND – 0.3V) to (OV A 7 10 CMOS/LVDS DD + 0.3V) IN– GND 8 9 CNV Digital Output Voltage MSE PACKAGE (Note 3) .. (GND – 0.3V) to (OV 16-LEAD (4mm × 5mm) PLASTIC MSOP DD + 0.3V) Power Dissipation ...200mW TJMAX = 150°C, θJA = 40°C/W EXPOSED PAD (PIN 17) IS GND, MUST BE SOLDERED TO PCB Operating Temperature Range LTC2311C ... 0°C to 70°C LTC2311I ..–40°C to 85°C LTC2311H .. –40°C to 125°C Storage Temperature Range .. –65°C to 150°C
ORDER INFORMATION http://www.linear.com/product/LTC2311-14#orderinfo LEAD FREE FINISH TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION TEMPERATURE RANGE
LTC2311CMSE-14#PBF LTC2311CMSE-14#TRPBF 231114 16-Lead (4mm × 5mm) Plastic MSOP 0°C to 70°C LTC2311IMSE-14#PBF LTC2311IMSE-14#TRPBF 231114 16-Lead (4mm × 5mm) Plastic MSOP –40°C to 85°C LTC2311HMSE-14#PBF LTC2311HMSE-14#TRPBF 231114 16-Lead (4mm × 5mm) Plastic MSOP –40°C to 125°C Consult LTC Marketing for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/. Some packages are available in 500 unit reels through designated sales channels with #TRMPBF suffix. 231114fa 2 For more information www.linear.com/LTC2311-14 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Electrical Characteristics Converter Characteristics Dynamic Accuracy Internal Reference Characteristics Digital Inputs And Digital Outputs Power Requirements ADC Timing Characteristics Typical Performance Characteristics Functional Block Diagram Timing Diagram Applications Information Package Description Related Parts Features Applications Typical Application Description Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics Converter Characteristics Dynamic Accuracy Internal Reference Characteristics Digital Inputs And Digital Outputs Power Requirements ADC Timing Characteristics Typical Performance Characteristics Pin Functions Functional Block Diagram Timing Diagram Applications Information OVERVIEW CONVERTER OPERATION TRANSFER FUNCTION INPUT DRIVE CIRCUITS ADC REFERENCE DYNAMIC PERFORMANCE POWER CONSIDERATIONS TIMING AND CONTROL DIGITAL INTERFACE BOARD LAYOUT Package Description Revision History Typical Application Related Parts
