Клеммники KEEN SIDE
Datasheet LTC2321-12 (Analog Devices) - 6
ОписаниеDual, 12-Bit + Sign, 2Msps Differential Input ADC with Wide Input Common Mode Range
Страниц / Страница26 / 6 — ADC. TIMING CHARACTERISTICS The. denotes the specifications which apply …
ADC. TIMING CHARACTERISTICS The. denotes the specifications which apply over the full operating
ADC TIMING CHARACTERISTICS The denotes the specifications which apply over the full operating
22 предложений от 13 поставщиков
IC ADC 12BIT SAR 28QFN. 12 Bit Analog to Digital Converter 2 Input 2 SAR 28-QFN (4x5). Data Acquisition - Analog...
LTC2321HUFD-12#TRPBF
283 ₽
Рутоника
659 ₽
LTC2321HUFD-12#PBF
1 334 ₽
Эиком
LTC2321HUFD-12#PBF
от 1 887 ₽
LTC2321-12
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C (Note 4). SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
fSMPL Maximum Sampling Frequency l 2 Msps tCYC Time Between Conversions (Note 11) tCYC = tCNVH + tCONV + tREADOUT l 500 1000000 ns tCONV Conversion Time l 220 ns tCNVH CNV High Time l 30 ns tDSCKHNVH SCK Delay Time to CNV↑ (Note 11) l 0 ns tSCK SCK Period (Notes 12, 13) l 15.6 ns tSCKH SCK High Time l 7 ns tSCKL SCK Low Time l 7 ns tDSCKCLKOUT SCK to CLKOUT Delay (Note 12) l 2.8 ns tDCLKOUTSDOV SDO Data Valid Delay from CLKOUT↓ CL = 5pF (Note 12) l 2.5 ns tHSDO SDO Data Remains Valid Delay from CL = 5pF (Note 11) l 2.5 ns CLKOUT↓ tDCNVSDOV SDO Data Valid Delay from CNV↓ CL = 5pF (Note 11) l 2.5 3 ns tDCNVSDOZ Bus Relinquish Time After CNV↑ (Note 11) l 3 ns tWAKE REFOUT1,2 Wake-Up Time CREFOUT1,2 = 10μF 10 ms
Note 1:
Note 8:
All specifications in dB are referred to a full-scale ±4.096V input may cause permanent damage to the device. Exposure to any Absolute with REFOUT = 4.096V. Maximum Rating condition for extended periods may affect device
Note 9:
When REFOUT1,2 is overdriven, the internal reference buffer must reliability and lifetime. be turned off by setting REFINT = 0V.
Note 2:
All voltage values are with respect to ground.
Note 10:
fSMPL = 2MHz, IREFBUF varies proportionally with sample rate.
Note 3:
When these pin voltages are taken below ground, or above VDD
Note 11:
Guaranteed by design, not subject to test. or OVDD, they will be clamped by internal diodes. This product can handle
Note 12:
Parameter tested and guaranteed at OV input currents up to 100mA below ground, or above V DD = 1.71V and DD or OVDD, without OV latch-up. DD = 2.5V.
Note 13:
t
Note 4
: V SCK of 15.6ns maximum allows a shift clock frequency up to DD = 5V, OVDD = 2.5V, REFOUT1,2 = 4.096V, fSMPL = 2MHz. 64MHz for rising edge capture.
Note 5:
Recommended operating conditions.
Note 14:
Temperature coefficient is calculated by dividing the maximum
Note 6:
Integral nonlinearity is defined as the deviation of a code from a change in output voltage by the specified temperature range. straight line passing through the actual endpoints of the transfer curve.
Note 15:
CNV is driven from a low jitter digital source, typically at OV The deviation is measured from the center of the quantization band. DD logic levels. This input pin has a TTL style input that will draw a small
Note 7:
Bipolar zero error is the offset voltage measured from –0.5LSB amount of current. when the output code flickers between 0 0000 0000 0000 and 1 1111
Note 16:
1LSB = 2 • REFOUT1,2/212 1111 1111. Full-scale bipolar error is the worst-case of –FS or +FS un- trimmed deviation from ideal first and last code transitions and includes the effect of offset error. 0.8 • OVDD tWIDTH 0.2 • OVDD t tDELAY 50% 50% DELAY 232112 F01 0.8 • OVDD 0.8 • OVDD 0.2 • OVDD 0.2 • OVDD
Figure 1. Voltage Levels for Timing Specifications
232112fb 6 For more information www.linear.com/LTC2321-12 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Converter Characteristics Dynamic Accuracy Internal Reference Characteristics Digital Inputs And Digital Outputs Power Requirements ADC Timing Characteristics Typical Performance Characteristics Pin Functions Functional Block Diagram Timing Diagram Applications Information Package Description Related Parts
