Datasheet LTC2351-12 (Analog Devices) - 3
Описание6 Channel, 12-Bit, 1.5Msps Simultaneous Sampling ADC with Shutdown
Страниц / Страница20 / 3 — ANALOG INPUT. The. denotes the specifi cations which apply over the full …
Формат / Размер файлаPDF / 235 Кб
ANALOG INPUT. The. denotes the specifi cations which apply over the full operating temperature range,
ANALOG INPUT The denotes the specifi cations which apply over the full operating temperature range,
20 предложений от 11 поставщиков
, 6 Channel, 12-Bit, 1.5Msps Simultaneous Sampling ADC with Shutdown
LTC2351HUH-12#TRPBF
754 ₽
LTC2351HUH-12#PBF
от 2 158 ₽
Эиком
LTC2351HUH-12#PBF
от 2 389 ₽
LTC2351HUH-12 PBF
LTC2351-12
ANALOG INPUT The
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. With internal reference, VDD = VCC = 3V. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VIN Analog Differential Input Range (Notes 3, 8, 9) 2.7V ≤ VDD ≤ 3.6V, Unipolar 0 to 2.5 V 2.7V ≤ VDD ≤ 3.6V, Bipolar ±1.25 V VCM Analog Common Mode + Differential Input Range (Note 8) 0 to VDD V IIN Analog Input Leakage Current l 1 μA CIN Analog Input Capacitance 13 pF tACQ Sample-and-Hold Acquisition Time (Note 6) l 39 ns tAP Sample-and-Hold Aperture Delay Time 1 ns tJITTER Sample-and-Hold Aperture Delay Time Jitter 0.3 ps tSK Channel to Channel Aperture Skew 200 ps CMRR Analog Input Common Mode Rejection Ratio fIN = 100kHz, VIN = 0V to 3V –83 dB fIN = 10MHz, VIN = 0V to 3V –67 dB
DYNAMIC ACCURACY The
l
SINAD Signal-to-Noise Plus Distortion Ratio 100kHz Input Signal l 69 72 dB 300kHz Input Signal 71 dB 100kHz Input Signal (LTC2351H-12) l 68 72 dB THD Total Harmonic Distortion 100kHz First 5 Harmonics l –80 –90 dB 300kHz First 5 Harmonics –85 dB 100kHz First 5 Harmonics (LTC2351H-12) l –79 –89 dB SFDR Spurious Free Dynamic Range 100kHz Input Signal 90 dB 300kHz Input Signal 85 dB IMD Intermodulation Distortion 0.625VP-P, 833kHz into CH0+, 0.625VP-P, 841kHz into CH0– –80 dB Bipolar Mode. Also Applicable to Other Channels Code-to-Code Transition Noise VREF = 2.5V (Note 17) 0.2 LSBRMS Full Power Bandwidth VIN = 2.5VP-P, SDO = 11585LSBP-P (–3dBFS) (Note 15) 50 MHz Full Linear Bandwidth S/(N + D) ≥ 68dB, Bipolar Differential Input 5 MHz
INTERNAL REFERENCE CHARACTERISTICS TA = 25°C. VDD = VCC = 3V. PARAMETER CONDITIONS MIN TYP MAX UNITS
VREF Output Voltage IOUT = 0 2.5 V VREF Output Tempco 15 ppm/°C VREF Line Regulation VDD = 2.7V to 3.6V, VREF = 2.5V 600 μV/V VREF Output Resistance Load Current = 0.5mA 0.2 Ω VREF Settling Time Ext CREF = 10μF 2 ms External VREF Input Range 2.55 VDD V 235112fa 3
