Datasheet LTC2351-12 (Analog Devices) - 4
Описание6 Channel, 12-Bit, 1.5Msps Simultaneous Sampling ADC with Shutdown
Страниц / Страница20 / 4 — DIGITAL INPUTS AND DIGITAL OUTPUTS. The. denotes the specifi cations which …
Формат / Размер файлаPDF / 235 Кб
DIGITAL INPUTS AND DIGITAL OUTPUTS. The. denotes the specifi cations which apply over the
DIGITAL INPUTS AND DIGITAL OUTPUTS The denotes the specifi cations which apply over the
25 предложений от 19 поставщиков
IC ADC 12BIT 32QFN. 12 Bit Analog to Digital Converter 6 Input 1 32-QFN (5x5). Data Acquisition - Analog to Digital...
LTC2351IUH-12#PBF
557 ₽
LTC2351IUH-12#PBF
1 749 ₽
LTC2351IUH-12#TRPBF
Hi-Tech Circuit Group
LTC2351IUH-12#TRPBF
LTC2351-12
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VDD = VCC = 3V. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VIH High Level Input Voltage VDD = 3.3V l 2.4 V VIL Low Level Input Voltage VDD = 2.7V l 0.6 V IIN Digital Input Current VIN = 0V to VDD l ±10 μA CIN Digital Input Capacitance 5 pF VOH High Level Output Voltage VDD = 3V, IOUT = –200μA l 2.5 2.9 V VOL Low Level Output Voltage VDD = 2.7V, IOUT= 160μA 0.05 V VDD = 2.7V, IOUT = 1.6mA l 0.4 V IOZ Hi-Z Output Leakage DOUT VOUT = 0V and VDD l ±10 μA COZ Hi-Z Output Capacitance DOUT 1 pF ISOURCE Output Short-Circuit Source Current VOUT = 0V, VDD = 3V 20 mA ISINK Output Short-Circuit Sink Current VOUT = VDD = 3V 15 mA
POWER REQUIREMENTS The
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. With internal reference, VDD = VCC = 3V. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VDD, VCC Supply Voltage 2.7 3.0 3.6 V IDD + ICC Supply Current Active Mode, fSAMPLE = 1.5Msps l 5.5 8 mA Active Mode, fSAMPLE = 1.5Msps (LTC2351H-12) l 6 9 mA Nap Mode l 1.5 2 mA Nap Mode (LTC2351H-12) l 1.8 2.5 mA Sleep Mode 4.0 15 μA PD Power Dissipation Active Mode with SCK, fSAMPLE = 1.5Msps 16.5 mW
TIMING CHARACTERISTICS The
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VDD = 3V. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
fSAMPLE(MAX) Maximum Sampling Rate per Channel l 250 kHz (Conversion Rate) tTHROUGHPUT Minimum Sampling Period (Conversion + Acquisiton Period) l 4 μs tSCK Clock Period (Note 16) l 40 10000 ns tCONV Conversion Time (Notes 6, 17) 96 SCLK cycles t1 Minimum High or Low SCLK Pulse Width (Note 6) 2 ns t2 CONV to SCK Setup Time (Notes 6, 10) 3 10000 ns t3 SCK Before CONV (Note 6) 0 ns t4 Minimum High or Low CONV Pulse Width (Note 6) 4 ns t5 SCK↑ to Sample Mode (Note 6) 4 ns t6 CONV↑ to Hold Mode (Notes 6, 11) 1.2 ns t7 96th SCK↑ to CONV↑ Interval (Affects Acquisition Period) (Notes 6, 7, 13) 45 ns t8 Minimum Delay from SCK to Valid Bits 0 Through 11 (Notes 6, 12) 8 ns 235112fa 4
