Клеммники KEEN SIDE
Datasheet LTC2376-16 (Analog Devices) - 10
Описание16-Bit, 250ksps, Low Power SAR ADC with 97dB SNR
Страниц / Страница26 / 10 — APPLICATIONS INFORMATION. OVERVIEW. TRANSFER FUNCTION. Figure 2. …
Формат / Размер файлаPDF / 2.1 Мб
APPLICATIONS INFORMATION. OVERVIEW. TRANSFER FUNCTION. Figure 2. LTC2376-16 Transfer Function. ANALOG INPUT. CONVERTER OPERATION
APPLICATIONS INFORMATION OVERVIEW TRANSFER FUNCTION Figure 2 LTC2376-16 Transfer Function ANALOG INPUT CONVERTER OPERATION
32 предложений от 18 поставщиков
IC ADC 16BIT SAR 16MSOP. 16 Bit Analog to Digital Converter 1 Input 1 SAR 16-MSOP. Data Acquisition - Analog to...
LTC2376IMS-16#TRPBF
1 135 ₽
LTC2376IMS-16#PBF
1 827 ₽
Зенер
Россия и страны ТС
LTC2376IMS-16#PBF
от 2 737 ₽
LTC2376IMS-16 PBF
LTC2376-16
The LTC2376-16 is a low noise, low power, high speed The LTC2376-16 digitizes the full-scale voltage of 2 × REF 16-Bit successive approximation register (SAR) ADC. into 216 levels, resulting in an LSB size of 152µV with Operating from a single 2.5V supply, the LTC2376-16 REF = 5V. The ideal transfer function is shown in Figure 2. supports a large and flexible ±VREF fully differential input The output data is in 2’s complement format. range with VREF ranging from 2.5V to 5.1V, making it ideal for high performance applications which require a wide 011...111 dynamic range. The LTC2376-16 achieves ±0.5LSB INL 011...110 BIPOLAR max, no missing codes at 16 bits and 97dB SNR. ZERO Fast 250ksps throughput with no cycle latency makes 000...001 000...000 the LTC2376-16 ideally suited for a wide variety of high 111...111 speed applications. An internal oscillator sets the con- 111...110 version time, easing external timing considerations. The LTC2376-16 dissipates only 3.4mW at 250ksps, while an 100...001 FSR = +FS – –FS auto power-down feature is provided to further reduce OUTPUT CODE (TWO’S COMPLEMENT) 100...000 1LSB = FSR/65536 power dissipation during inactive periods. –FSR/2 –1 0V 1 FSR/2 – 1LSB LSB LSB The LTC2376-16 features a unique digital gain compres- INPUT VOLTAGE (V) 237616 F02 sion (DGC) function, which eliminates the driver amplifier’s
negative supply while preserving the full resolution of the ADC. When enabled, the ADC performs a digital scaling
ANALOG INPUT
function that maps zero-scale code from 0V to 0.1 • VREF The analog inputs of the LTC2376-16 are fully differential and full-scale code from VREF to 0.9 • VREF. For a typical in order to maximize the signal swing that can be digitized. reference voltage of 5V, the full-scale input range is now The analog inputs can be modeled by the equivalent circuit 0.5V to 4.5V, which provides adequate headroom for shown in Figure 3. The diodes at the input provide ESD powering the driving amplifier from a single 5.5V supply. protection. In the acquisition phase, each input sees ap- proximately 45pF (CIN) from the sampling CDAC in series
CONVERTER OPERATION
with 40Ω (RON) from the on-resistance of the sampling switch. Any unwanted signal that is common to both The LTC2376-16 operates in two phases. During the ac- inputs will be reduced by the common mode rejection of quisition phase, the charge redistribution capacitor D/A the ADC. The inputs draw a current spike while charging converter (CDAC) is connected to the IN+ and IN– pins the CIN capacitors during acquisition. During conversion, to sample the differential analog input voltage. A rising the analog inputs draw only a small leakage current. edge on the CNV pin initiates a conversion. During the conversion phase, the 16-bit CDAC is sequenced through a REF C R IN successive approximation algorithm, effectively comparing ON 45pF 40Ω the sampled input with binary-weighted fractions of the IN+ reference voltage (e.g. VREF/2, VREF/4 … VREF/65536) using the differential comparator. At the end of conversion, the BIAS REF VOLTAGE CDAC output approximates the sampled analog input. The C R IN ON 45pF ADC control logic then prepares the 16-bit digital output 40Ω IN– code for serial transfer. 237616 F03
Figure 3. The Equivalent Circuit for the Differential Analog Input of the LTC2376-16
237616fa 10 For more information www.linear.com/LTC2376-16 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Converter Characteristics Dynamic Accuracy Reference Input Digital Inputs and Digital Outputs Power Requirements ADC Timing Characteristics Typical Performance Characteristics Pin Functions Functional Block Diagram Timing Diagram Applications Information Board Layout Typical Application Related Parts Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Converter Characteristics Dynamic Accuracy Reference Input Digital Inputs and Digital Outputs Power Requirements ADC Timing Characteristics Typical Performance Characteristics Pin Functions Functional Block Diagram Timing Diagram Applications Information Board Layout Package Description Revision History Typical Application Related Parts
