Datasheet LTC2410 (Analog Devices) - 10
Описание24-Bit No Latency ∆Σ™ ADC with Differential Input and Differential Reference
Страниц / Страница50 / 10 — PIN FUNCTIONS GND (Pins 1, 7, 8, 9, 10, 15, 16):. SDO (Pin 12):. VCC (Pin …
Формат / Размер файлаPDF / 804 Кб
PIN FUNCTIONS GND (Pins 1, 7, 8, 9, 10, 15, 16):. SDO (Pin 12):. VCC (Pin 2):. SCK (Pin 13):. REF+ (Pin 3), REF– (Pin 4):
PIN FUNCTIONS GND (Pins 1, 7, 8, 9, 10, 15, 16): SDO (Pin 12): VCC (Pin 2): SCK (Pin 13): REF+ (Pin 3), REF– (Pin 4):
23 предложений от 14 поставщиков
Микросхема Преобразователь AD, IC ADC 24Bit DIFF INP/REF 16SSOP
LTC2410CGN#TRPBF
571 ₽
LTC2410CGN#TRPBF
949 ₽
LTC2410CGN#TRPBF
1 172 ₽
Эиком
LTC2410CGN#TRPBF
от 1 657 ₽
LTC2410
Ground. Multiple
SDO (Pin 12):
Three-State Digital Output. During the Data ground pins internally connected for optimum ground Output period, this pin is used as serial data output. When current flow and VCC decoupling. Connect each one of the chip select CS is HIGH (CS = VCC) the SDO pin is in a these pins to a ground plane through a low impedance high impedance state. During the Conversion and Sleep connection. All seven pins must be connected to ground periods, this pin is used as the conversion status output. for proper operation. The conversion status can be observed by pulling CS LOW.
VCC (Pin 2):
Positive Supply Voltage. Bypass to GND
SCK (Pin 13):
Bidirectional Digital Clock Pin. In Internal (Pin 1) with a 10µF tantalum capacitor in parallel with Serial Clock Operation mode, SCK is used as digital output 0.1µF ceramic capacitor as close to the part as possible. for the internal serial interface clock during the Data Output
Differential Reference Input. period. In External Serial Clock Operation mode, SCK is The voltage on these pins can have any value between used as digital input for the external serial interface clock GND and V during the Data Output period. A weak internal pull-up is CC as long as the reference positive input, REF+, is maintained more positive than the reference negative automatically activated in Internal Serial Clock Operation input, REF–, by at least 0.1V. mode. The Serial Clock Operation mode is determined by the logic level applied to the SCK pin at power up or during
IN+ (Pin 5), IN– (Pin 6):
Differential Analog Input. The the most recent falling edge of CS. voltage on these pins can have any value between GND – 0.3V and V
FO (Pin 14):
Frequency Control Pin. Digital input that CC + 0.3V. Within these limits the con- verter bipolar input range (V controls the ADC’s notch frequencies and conversion IN = IN+ – IN–) extends from –0.5 • (V time. When the FO pin is connected to VCC (FO = VCC), the REF) to 0.5 • (VREF). Outside this input range the converter produces unique overrange and underrange converter uses its internal oscillator and the digital filter output codes. first null is located at 50Hz. When the FO pin is connected to GND (FO = OV), the converter uses its internal oscillator
CS (Pin 11):
Active LOW Digital Input. A LOW on this pin and the digital filter first null is located at 60Hz. When FO is enables the SDO digital output and wakes up the ADC. driven by an external clock signal with a frequency fEOSC, Following each conversion the ADC automatically enters the converter uses this signal as its system clock and the the Sleep mode and remains in this low power state as digital filter first null is located at a frequency fEOSC/2560. long as CS is HIGH. A LOW-to-HIGH transition on CS during the Data Output transfer aborts the data transfer and starts a new conversion. 2410fa 10 For more information www.linear.com/LTC2410 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Electrical Characteristics Pin Configuration Electrical Characteristics Converter Characteristics Analog Input and Reference Digital Inputs and Digital Outputs Power Requirements Timing Characteristics Typical Performance Characteristics Pin Functions Functional Block Diagram Test Circuit Applications Information Typical Applications Package Description PCB Layout and Film Revision History PCB Layout and Film Related Parts
