Datasheet LTC2413 (Analog Devices) - 4
Описание24-Bit No Latency ∆Σ™ ADC with Simultaneous 50Hz/60Hz Rejection
Страниц / Страница46 / 4 — conver. Ter characTerisTics The. denotes the specifications which apply …
Формат / Размер файлаPDF / 526 Кб
conver. Ter characTerisTics The. denotes the specifications which apply over the full operating
conver Ter characTerisTics The denotes the specifications which apply over the full operating
27 предложений от 15 поставщиков
Микросхема Преобразователь AD, LTC2413 - 24Bit No Latency Delta Sigma ADC with Simultaneous 50Hz/60Hz Rejection ADC,
727GS
LTC2413CGN#PBF
от 346 ₽
LTC2413CGN#PBF
389 ₽
Эиком
LTC2413CGN#PBF
от 1 648 ₽
LTC2413CGN
LTC2413
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Notes 3, 4) PARAMETER CONDITIONS MIN TYP MAX UNITS
Input Common Mode Rejection DC 2.5V ≤ REF+ ≤ VCC, REF– = GND, l 130 140 dB GND ≤ IN– = IN+ ≤ VCC Input Common Mode Rejection 2.5V ≤ REF+ ≤ VCC, REF– = GND, l 140 dB 49Hz to 61.2Hz GND ≤ IN– = IN+ ≤ VCC, (Note 7) Input Normal Mode Rejection (Note 7) l 87 dB 49Hz to 61.2Hz Input Normal Mode Rejection External Oscillator l 87 dB External Clock fEOSC/2560 ±14% Input Normal Mode Rejection External Oscillator l 110 140 dB External Clock fEOSC/2560 ±4% Reference Common Mode 2.5V ≤ REF+ ≤ VCC, GND ≤ REF– ≤ 2.5V, l 130 140 dB Rejection DC VREF = 2.5V, IN– = IN+ = GND Power Supply Rejection, DC REF+ = 2.5V, REF– = GND, IN– = IN+ = GND 120 dB Power Supply Rejection REF+ = 2.5V, REF– = GND, 120 dB Simultaneous 50Hz/60Hz ±2% IN– = IN+ = GND, (Note 7)
analog inpuT anD reFerence The
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Note 3) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
IN+ Absolute/Common Mode IN+ Voltage l GND – 0.3V VCC + 0.3V V IN– Absolute/Common Mode IN– Voltage l GND – 0.3V VCC + 0.3V V VIN Input Differential Voltage Range l –VREF/2 –VREF/2 V (IN+ – IN–) REF+ Absolute/Common Mode REF+ Voltage l 0.1 VCC V REF– Absolute/Common Mode REF– Voltage l GND VCC – 0.1V V VREF Reference Differential Voltage Range l 0.1 VCC V (REF+ – REF–) CS (IN+) IN+ Sampling Capacitance 18 pF CS (IN–) IN– Sampling Capacitance 18 pF CS (REF+) REF+ Sampling Capacitance 18 pF CS (REF–) REF– Sampling Capacitance 18 pF IDC_LEAK (IN+) IN+ DC Leakage Current CS = VCC, IN+ = GND l –10 1 10 nA IDC_LEAK (IN–) IN– DC Leakage Current CS = VCC, IN– = GND l –10 1 10 nA IDC_LEAK (REF+) REF+ DC Leakage Current CS = VCC, REF+ = 5V l –10 1 10 nA IDC_LEAK (REF–) REF– DC Leakage Current CS = VCC, REF– = GND l –10 1 10 nA 2413fa 4 For more information www.linear.com/LTC2413
