Datasheet LTC2430, LTC2431 (Analog Devices) - 3
Описание20-Bit No Latency ∆Σ™ ADCs with Differential Input and Differential Reference
Страниц / Страница40 / 3 — CO VERTER CHARACTERISTICS The. denotes specifications which apply over …
Формат / Размер файлаPDF / 466 Кб
CO VERTER CHARACTERISTICS The. denotes specifications which apply over the full operating
CO VERTER CHARACTERISTICS The denotes specifications which apply over the full operating
29 предложений от 19 поставщиков
, 20-Bit No Latency ∆ΣTM ADCs with Differential Input and Differential Reference
LTC2431IMS#TRPBF
174 ₽
SUV System
LTC2431IMS#TRPBF
TradeElectronics
LTC2431IMS
LTC2431IMS#TRPBF
LTC2430/LTC2431
U CO VERTER CHARACTERISTICS The
denotes specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25
C. (Notes 3, 4) PARAMETER CONDITIONS MIN TYP MAX UNITS
Input Common Mode Rejection DC 2.5V ≤ REF+ ≤ VCC, REF– = GND, ● 110 120 dB GND ≤ IN– = IN+ ≤ 5V (Note 5) Input Common Mode Rejection 2.5V ≤ REF+ ≤ VCC, REF– = GND, ● 140 dB 60Hz ±2% GND ≤ IN– = IN+ ≤ 5V, (Notes 5, 7) Input Common Mode Rejection 2.5V ≤ REF+ ≤ VCC, REF– = GND, ● 140 dB 50Hz ±2% GND ≤ IN– = IN+ ≤ 5V, (Notes 5, 8) Input Normal Mode Rejection (Notes 5, 7) ● 110 140 dB 60Hz ±2% Input Normal Mode Rejection (Notes 5, 8) ● 110 140 dB 50Hz ±2% Reference Common Mode 2.5V ≤ REF+ ≤ VCC, GND ≤ REF– ≤ 2.5V, ● 130 140 dB Rejection DC VREF = 2.5V, IN– = IN+ = GND (Note 5) Power Supply Rejection, DC REF+ = 2.5V, REF– = GND, IN– = IN+ = GND 110 dB Power Supply Rejection, 60Hz ±2% REF+ = 2.5V, REF– = GND, IN– = IN+ = GND, (Note 7) 120 dB Power Supply Rejection, 50Hz ±2% REF+ = 2.5V, REF– = GND, IN– = IN+ = GND, (Note 8) 120 dB
U U U U A ALOG I PUT A D REFERE CE The
C. (Note 3) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
IN+ Absolute/Common Mode IN+ Voltage ● GND – 0.3V VCC + 0.3V V IN– Absolute/Common Mode IN– Voltage ● GND – 0.3V VCC + 0.3V V VIN Input Differential Voltage Range ● – VREF/2 VREF/2 V (IN+ – IN–) REF+ Absolute/Common Mode REF+ Voltage ● 0.1 VCC V REF– Absolute/Common Mode REF– Voltage ● GND VCC – 0.1V V VREF Reference Differential Voltage Range ● 0.1 VCC V (REF+ – REF–) CS (IN+) IN+ Sampling Capacitance 1.5 pF CS (IN–) IN– Sampling Capacitance 1.5 pF CS (REF+) REF+ Sampling Capacitance 1.5 pF CS (REF–) REF– Sampling Capacitance 1.5 pF IDC_LEAK (IN+) IN+ DC Leakage Current CS = VCC, IN+ = GND ● –10 1 10 nA IDC_LEAK (IN–) IN– DC Leakage Current CS = VCC, IN– = VCC ● –10 1 10 nA IDC_LEAK (REF+) REF+ DC Leakage Current CS = VCC, REF+ = VCC ● –10 1 10 nA IDC_LEAK (REF–) REF– DC Leakage Current CS = VCC, REF– = GND ● –10 1 10 nA 24301f 3
