Datasheet LTC2442 (Analog Devices) - 4
Описание24-Bit High Speed 4-Channel ΔΣ ADC with Integrated Amplifier
Страниц / Страница32 / 4 — DIGITAL INPUTS AND DIGITAL OUTPUTS The. denotes the specifications which …
Формат / Размер файлаPDF / 397 Кб
DIGITAL INPUTS AND DIGITAL OUTPUTS The. denotes the specifications which apply over the
DIGITAL INPUTS AND DIGITAL OUTPUTS The denotes the specifications which apply over the
29 предложений от 17 поставщиков
Микросхема Преобразователь AD, LINEAR TECHNOLOGY LTC2442CG#PBF Analog to Digital Converter, 24Bit, 8KSPS, Single, 4.5V, 5.5V, SSOP
LTC2442CG#PBF
563 ₽
ЧипСити
LTC2442CG#PBF
718 ₽
LTC2442CG
LTC2442CG
LTC2442
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Note 3) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VIH High Level Input Voltage 4.5V ≤ VCC ≤ 5.5V l 2.5 V CS, FO, EXT, SDI VIL Low Level Input Voltage 4.5V ≤ VCC ≤ 5.5V l 0.8 V CS, FO, EXT, SDI VIH High Level Input Voltage 4.5V ≤ VCC ≤ 5.5V (Note 8) l 2.5 V SCK VIL Low Level Input Voltage 4.5V ≤ VCC ≤ 5.5V (Note 8) l 0.8 V SCK IIN Digital Input Current 0V ≤ VIN ≤ VCC l –10 10 µA CS, FO, EXT, SDI IIN Digital Input Current 0V ≤ VIN ≤ VCC (Note 8) l –10 10 µA SCK CIN Digital Input Capacitance 10 pF CS, FO, EXT, SDI CIN Digital Input Capacitance (Note 8) 10 pF SCK VOH High Level Output Voltage IO = –800µA l VCC – 0.5 V SDO, BUSY VOL Low Level Output Voltage IO = 1.6µA l 0.4 V SDO, BUSY VOH High Level Output Voltage IO = –800µA (Note 9) l VCC – 0.5 V SCK VOL Low Level Output Voltage IO = 1.6µA (Note 9) l 0.4 V SCK IOZ Hi-Z Output Leakage l –10 10 µA SDO
POWER REQUIREMENTS The
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Notes 3) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VCC Supply Voltage l 4.5 5.5 V V+ Amplifier Positive Supply l 4.5 15 V V– Amplifier Negative Supply l –15 0 V ICC Supply Current Amplifiers and ADC l 10 13 mA 2442fb 4 For more information www.linear.com/LTC2442
