Datasheet LTC2482 (Analog Devices) - 3
Описание16-Bit ΔΣ ADC with Easy Drive Input Current Cancellation
Страниц / Страница32 / 3 — CONVERTER CHARACTERISTICS. The. denotes the specifi cations which apply …
Формат / Размер файлаPDF / 325 Кб
CONVERTER CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
CONVERTER CHARACTERISTICS The denotes the specifi cations which apply over the full operating
28 предложений от 20 поставщиков
Микросхема Преобразователь AD, LINEAR TECHNOLOGY LTC2482IDD#PBF Analog to Digital Converter, 16Bit, 6.8 SPS, Single, 2.7V, 5.5V, DFN
LTC2482IDD#PBF
150 ₽
LTC2482IDD#TRPBF
235 ₽
SUV System
LTC2482IDD#PBF
ТаймЧипс
LTC2482IDD-PBF
LTC2482
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. (Notes 3, 4) PARAMETER CONDITIONS MIN TYP MAX UNITS
Input Common Mode Rejection DC 2.5V ≤ VREF ≤ VCC, GND ≤ IN– = IN+ ≤ VCC (Note 5) l 140 dB Input Common Mode Rejection, 50Hz ±2% 2.5V ≤ VREF ≤ VCC, GND ≤ IN– = IN+ ≤ VCC (Note 5) l 140 dB Input Common Mode Rejection, 60Hz ±2% 2.5V ≤ VREF ≤ VCC, GND ≤ IN– = IN+ ≤ VCC (Note 5) l 140 dB Input Normal Mode Rejection, 50Hz ±2% 2.5V ≤ VREF ≤ VCC, GND ≤ IN– = IN+ ≤ VCC (Notes 5, 7) l 110 120 dB Input Normal Mode Rejection, 60Hz ±2% 2.5V ≤ VREF ≤ VCC, GND ≤ IN– = IN+ ≤ VCC (Notes 5, 8) l 110 120 dB Input Normal Mode Rejection, 50Hz/60Hz ±2% 2.5V ≤ VREF ≤ VCC, GND ≤ IN– = IN+ ≤ VCC (Notes 5, 9) l 87 dB Reference Common Mode Rejection DC 2.5V ≤ VREF ≤ VCC, GND ≤ IN– = IN+ ≤ VCC (Note 5) l 120 140 dB Power Supply Rejection DC VREF = 2.5V, IN– = IN+ = GND 120 dB Power Supply Rejection, 50Hz ±2% VREF = 2.5V, IN– = IN+ = GND (Note 7) 120 dB Power Supply Rejection, 60Hz ±2% VREF = 2.5V, IN– = IN+ = GND (Note 8) 120 dB
ANALOG INPUT AND REFERENCE The
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. (Note 3) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
IN+ Absolute/Common Mode IN+ Voltage GND – 0.3V VCC + 0.3V V IN– Absolute/Common Mode IN– Voltage GND – 0.3V VCC + 0.3V V FS Full Scale of the Differential Input (IN+ – IN–) l 0.5VREF V LSB Least Signifi cant Bit of the Output Code l FS/216 VIN Input Differential Voltage Range (IN+ – IN–) l –FS +FS V VREF Reference Voltage Range l 0.1 VCC V CS (IN+) IN+ Sampling Capacitance 11 pF CS (IN–) IN– Sampling Capacitance 11 pF CS (VREF) VREF Sampling Capacitance 11 pF IDC_LEAK (IN+) IN+ DC Leakage Current Sleep Mode, IN+ = GND l –10 1 10 nA IDC_LEAK (IN–) IN– DC Leakage Current Sleep Mode, IN– = GND l –10 1 10 nA IDC_LEAK (VREF) VREF Leakage Current Sleep Mode, VREF = VCC l –100 1 100 nA 2482fc 3
