Datasheet LTM9012 (Analog Devices) - 2
ОписаниеQuad 14-Bit, 125Msps ADC with Integrated Drivers
Страниц / Страница28 / 2 — absoluTe MaxiMuM raTings. pin conFiguraTion. (Notes 1, 2). orDer …
Формат / Размер файлаPDF / 2.1 Мб
absoluTe MaxiMuM raTings. pin conFiguraTion. (Notes 1, 2). orDer inForMaTion http://www.linear.com/product/LTM9012#orderinfo
absoluTe MaxiMuM raTings pin conFiguraTion (Notes 1, 2) orDer inForMaTion http://www.linear.com/product/LTM9012#orderinfo
LTM9012CY-AB PBF
LTM9012
Supply Voltages TOP VIEW VDD, OVDD .. –0.3V to 2V 1 2 3 4 5 6 7 8 9 10 11 12 13 V CH4+ CH4– CH3+ CH3– CH2+ CH2– CH1+ CH1– CC.. –0.3V to 5.5V A Analog Input Voltage (CHn+, CHn –, SHDNn ) B (Note 3) ...–0.3V to V V V CC3 CC2 CC C Analog Input Voltage (PAR/SER, SENSE) SHDN3 SHDN2 D (Note 4) .. –0.3V to (VDD + 0.2V) E Digital Input Voltage (ENC+, ENC–, CS, SDI, SCK) F SHDN4 SHDN1 (Note 5) ... –0.3V to 3.9V G VCC4 VCC1 SDO (Note 5)... –0.3V to 3.9V H Digital Output Voltage .. –0.3V to (OV J DD + 0.3V) Operating Temperature Range K LTM9012C ... 0°C to 70°C L SDI SENSE LTM9012I...–40°C to 85°C M VDD VDD N Storage Temperature Range .. –65°C to 150°C ENC+ SDO ENC– P PAR/SER CS REF Q OUT1A+ OUT4B– OUT4B+ OUT1A– R S FR– FR+ DCO– DCO+ OUT4A– OUT1B+ OUT3A– OUT3B– SCK OVDD OUT2A– OUT2B+ OUT4A+ OUT3B+ OUT2A+ OUT1B– OUT3A+ OUT2B– BGA PACKAGE ALL ELSE = GND 221-LEAD (15mm × 11.25mm) TJMAX = 125°C, θJA = 16.5°C/W, θJCtop = 15°C/W, θJCbottom = 6.3°C/W, θJBOARD = 10.4°C/W θ VALUES DETERMINED PER JESD 51-9 WEIGHT = 1.07g
orDer inForMaTion http://www.linear.com/product/LTM9012#orderinfo LEAD FREE FINISH TRAY PART MARKING* PACKAGE DESCRIPTION TEMPERATURE RANGE
LTM9012CY-AB#PBF LTM9012CY-AB#PBF LTM9012YAB 221-Lead (15mm × 11.25mm) Plastic BGA 0°C to 70°C LTM9012IY-AB#PBF LTM9012IY-AB#PBF LTM9012YAB 221-Lead (15mm × 11.25mm) Plastic BGA –40°C to 85°C Consult LTC Marketing for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/. Some packages are available in 500 unit reels through designated sales channels with #TRMPBF suffix. 9012fa 2 For more information www.linear.com/LTM9012 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Converter Characteristics Analog Input Dynamic Accuracy Internal Reference Characteristics Digital Inputs and Outputs Power Requirements Timing Characteristics Electrical Characteristics Timing Diagrams Typical Performance Characteristics Pin Functions Pin Configuration Table Block Diagram Applications Information Typical Application Package Description Revision History Typical Application Related Parts
