Линейка продуктов KEEN SIDE
Datasheet LTC1391 (Analog Devices) - 2
Описание8-Channel Analog Multiplexer with Cascadable Serial Interface
Страниц / Страница12 / 2 — ABSOLUTE AXI U RATI GS. PACKAGE/ORDER I FOR ATIO. (Note 1). ELECTRICAL …
ВерсияLTC1391: 8-Channel Analog Multiplexer with Cascadable Serial Interface Data Sheet
Формат / Размер файлаPDF / 185 Кб
ABSOLUTE AXI U RATI GS. PACKAGE/ORDER I FOR ATIO. (Note 1). ELECTRICAL CHARACTERISTICS The
ABSOLUTE AXI U RATI GS PACKAGE/ORDER I FOR ATIO (Note 1) ELECTRICAL CHARACTERISTICS The
29 предложений от 16 поставщиков
Коммутаторы, Мультиплексоры и Демультиплексоры
LTC1391CN#PBF
150 ₽
LTC1391CN
184 ₽
LTC1391CN#PBF
от 678 ₽
LTC1391CN#PBF
LTC1391
W W W U U W U ABSOLUTE AXI U RATI GS PACKAGE/ORDER I FOR ATIO (Note 1)
Total Supply Voltage (V + to V –) .. 15V TOP VIEW ORDER PART Input Voltage S0 1 16 V+ NUMBER Analog Inputs/Outputs ... (V – – 0.3V) to (V + + 0.3V) S1 2 15 D S2 3 14 V – LTC1391CGN Digital Inputs ...– 0.3V to 15V S3 4 13 D LTC1391CN Digital Outputs .. – 0.3V to (V + + 0.3V) OUT S4 5 12 D LTC1391CS Power Dissipation .. 500mW IN S5 6 11 CS LTC1391IGN Operating Temperature Range S6 7 10 CLK LTC1391IN LTC1391C ... 0°C to 70°C S7 8 9 GND LTC1391IS LTC1391I ... – 40°C to 85°C Storage Temperature Range ... – 65°C to 150°C GN PACKAGE N PACKAGE 16-LEAD PLASTIC SSOP 16-LEAD PDIP GN PART MARKING Lead Temperature (Soldering, 10 sec).. 300°C S PACKAGE 16-LEAD PLASTIC SO 1391 TJMAX = 125°C, θJA = 110°C/ W (GN) 1391I TJMAX = 125°C, θJA = 70°C/ W (N) TJMAX = 125°C, θJA = 100°C/ W (S) Consult LTC Marketing for parts specified with wider operating temperature ranges.
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25
C. V+ = 5V, V– = –5V, GND = 0V, unless otherwise specified. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS Switch
VANALOG Analog Signal Range (Note 2) ● – 5 5 V RON On-Resistance VS = ±3.5V, ID = 1mA TMIN = 0°C (LTC1391C) 75 Ω TMIN = –40°C (LTC1391I) 25°C 45 75 Ω TMAX = 70°C (LTC1391C) 120 Ω TMAX = 85°C (LTC1391I) ∆RON vs VS 20 % ∆RON vs Temperature 0.5 %/°C IS(OFF) Off Input Leakage VS = 4V, VD = – 4V, VS = – 4V, VD = 4V ±0.05 ±5 nA Channel Off ● ±20 nA ID(OFF) Off Output Leakage VS = 4V, VD = – 4V, VS = – 4V, VD = 4V ±0.05 ±5 nA Channel Off ● ±20 nA ID(ON) On Channel Leakage VS = VD = ±4V ±0.05 ±5 nA Channel On ● ±20 nA
Digital
VINH High Level Input Voltage V+ = 5.25V ● 2.4 V VINL Low Level Input Voltage V+ = 4.75V ● 0.8 V IINL, IINH Input Current VIN = 5V, 0V ● ±5 µA VOH High Level Output Voltage V+ = 4.75V, IO = – 10µA 4.74 V V+ = 4.75V, IO = – 360µA ● 2.4 4.50 V VOL Low Level Output Voltage V+ = 4.75V, IO = 1.6mA ● 0.5 0.8 V sn1391 1391fas 2
